Quick Question - Removing Rear Springs!?
Matt94GT
Hey whats involved I havent done it in years and forget can I do it with basic tools without smashing in my face when it pops out? I got some H&Rs chillin that ive been meaning to put in for months and I have nothing to do tonight!
I have aftermarket LCAs/UCAs if that matters.
Thanks
ryclef331
Put the car on jack stands so the rear axle can "sag." Put the jack back under the diff. Jack it up just slightly to push the axle up (to take the pressure off the shocks. Remove either the upper or lower shock bolt/nut. Lower the jack under the axle. The springs should practically fall out. Some times you got push down on one side at a time to "articulate" the axle but they will come out easy. With the axle all the way down like that and the shocks un hooked, there is hardly any tension on the springs at all. Its a cake walk. No need to worry about a spring to the face.
Matt94GT
Matt94GT
Sweet so just jack up by the axle after I put some jackstands under it, unbolt the shock and then just let the rear end down by the axle and thats it? awesome!
thanks
ryclef331
thanks
Thats it. Like I said, you might have to use your foot to push down on the brake disc to get the axle to sag enough for the spring to fall out.
Red96GT
You'll need to unbolt the quad shocks as well before lowering the axle. No biggie.
Schiffy
Norfolk, Va
No you don't... I did the first time, but not the second time. you can do it either way. if you got new U/L control arms, you don't need the quad shocks anyways, so :dunno:
bany95
Watch the brake line. If you just let the axle drop, you'll be hanging it off a 14 year old rubber hose... and that's not good.
Matt94GT
Matt94GT
no man MM doesnt make them for the tokico illumias I wish I went adjustable LCAs....fawk what was I thinking.
anyways it dropped about 1/4" more...better then my cut eibach pros i had in the rear lol.
