rear end "thunk"
joekd
Ct
Recently I started to get a rear end "thunk" over large bumps or when I have a passenger in the rear, suspension is all stock and the only thing I have done to the rear is remove the "dogbone" from where the driveshaft meets the rear
Checked under the car, no tires are hitting and the rear end snubber still looks perfect. Exhaust is OEM as well and not a mark on it, driveshaft looks fine too.
Any idea what else to check? It is a definate that the noise is coming from the rear
joekd
joekd
Ct
How do you figure? I did the shock bounce test and it was fine plus no sign of any leaking
joekd
joekd
Ct
Just questioning why you would even suspect shocks? I think bushings are next to check
Thanks
