roller rockers
I am curious how you know what length to get? I hear 1.6 alot and a couple of other numbers but have no idea what would work best for me. I have a set of trickflow heads NIB I need a set for, I already have tall valve covers and plan on using a trickflow stage 1 cam.
Pure84GTT
most cam shafts are based off of a 1.62:1 ratio
by stepping up to the 1.72:1 ratio you would be increasing your lift numbers on your cam specs essentially. unless your engine builder specifies that you run a different rocker ratio I would stick with the standard 1.6:1 ratio.
gregbar
Factory stock is 1.6. Stock Cobra is 1.7. You need to make sure there are no piston to valve clearance issues. You may be able to call Trickflow and they can give you the best way to go. I ve seen good results with 1.6 on intake and 1.7 on exhaust.
rz5.0
Great state of TEXAS
ive heard you can loose some power at low end with 1.7. ive heard good things about running the 1.6 and 1.7. like stated above. im too cheap to try it
5.0kid
ya, id just go ahead with the 1.6s. you can possible have ptv clearance issues with the 1.7s and then you'll just be out the money for the rockers and be behind again because you'll need to order some 1.6s. they are also easy to find used...
makes sense fellas. I was trying to keep everything trickflow to make sure it would work together so the idea of calling them sounds like it would make sence and I will give that a try. But thanks for the info as I am trying to learn all this.
Now educate me on lifters and pushrods? I have been told that you need to measure the pushrods to be sure they are the right length but it would seem to me that trickflow would probably know this as well right? I had a shop put on some systemax heads a couple of years ago and they put the wrong pushrods in. After we corrected it I had it dyno tuned and blew it on the dyno. I have always wondered if the short time we ran it with the wrong rods(10-15 mins maybe) caused this.
I assume I will want roller lifters as well?
Like I said, trying to learn so forgive the newb questions.
what brand would you consider to be a good deal on rockers? There are alot of brands that are half the price of TF, would they compair in quality? My car was formerly owned by my mother so I am never selling her and would like to do it right, and do it once. If it was that important to get the TF and pay that price I will but if there is a cheaper alternative that would last just as long what would it be?
rz5.0
cheap ones break. lifter i got new ones alot of people reuse the old one. you should also look into a harden oil pump driveshaft.
rz5.0
just do a search on rockers pretty sure you will find stories about them breaking and the oil pump driveshaft is cheap insurance. oem one can twist and break. when i bought my rockers the place i went to had a buch of broken ones from proform to scorpions so i got the comp cams pro magnums they have a livetime warranty
rz5.0
a lil over kill Comp Cams 1632-16 - Comp Cams Ultra Pro Magnum. but the tfs will be fine if i was to do it again i would do tfs or scorpions save some money.
