short bus time... what should i be making??
El_Diablo
hp wise with a vortech at 9psi, shorty headers, magnaflow catted x and flows out back, top it off with an edelbrock rpm top end and fms f cam, 42# injectors and so on.... stock with a MAF right now, soon to be tuned... all through a built AODE, any ideas?
LAFENATU
The stock heads are really robbing your power..
I would say in the range of 325-350..
E
El_Diablo
edelbrock top end meaning heads, upper and lower including neck and IIRC a 70mm TB ;)
LAFENATU
Well then...lol
Sorry I thought you meant just the manifold.
I would say around 400.. give or take. AODE's rob a lot of power, put a 2.95 pulley on it and get a tune and you'll hit 450 easily. What stall is your converter?
Numbers are just numbers though, the real test is on the track. :eek:ccasion14:
E
El_Diablo
i was thinking AFM powerpipe instead of the pulley...... i want to go meth but knowing me it would be empty every day, cant recall what stall it is, PO trashed the papers :(
i really just want a car that will run 12's and still stay together....
LAFENATU
Your def in the 12's hands down.
With a powerpipe and a dyno tune you will be be in the mid - low 12s consistantly.
.02
E
El_Diablo
thats where i would like to be.... sadly i cant hook up on 295 street tires.... and that was before the heads and cam, we'll see in a few weeks how it hooks now
LAFENATU
Do yourself a favor and buy some Nitto 555R's at the least. If not, all that power will never see the ground.
E
El_Diablo
its a daily driver....... i would rather keep the street tires for now
what would you estimate power to be if i swapped for a t5 or t56?
Venom351R
Maine
get a different set of tires/rims for the track.
Manuals usually see about a 5% better retention in HP from drive line loss then auto's do
E
El_Diablo
that would be nice but right now im just trying to get the rebuild done and start on the suspension, then its new tires and black saleens....
E
El_Diablo
i cant recall the build sheet to much but it was fully rebuild, new clutches, steels, rebuilt valve body which im certain is not stock, it shifts like a raped ape and is line pressure adjustable.... its not your average AODE, just wish i had the build sheet for it :(
97 king cobra
For your HP, IMO going from street tires to some mickey thompson et streets will feel like gaining 50hp off the line, way bigger mod than anything else. Tires are the biggest bang per buck mod over gears, nitrous, suspension, supercharger etc....
E
El_Diablo
i agree.... thats why im going to swap to 10.5 wide saleens on the back with a 315 tire.... then the cobras will be up for sale and i might get a set of DR's but for now ive gotta shell out the $300-500 per tire to get 295's on the cobras :(
97 king cobra
Why spend the money 2x?! and $300-500?! You need to shop around!!! try americanmuscle.com or even summit!!!
E
El_Diablo
what do you mean pay twice? if i could afford to get new wheels right now i would, trust me... i need them, but a 295 is a safe tire size on a 9 inch wide wheel and i need to go through summer with them, after that i'll hopefully have enough for a set of saleens
btw.... summit is a 20-30 minute drive, tops.... been there done that :)
