Should I need CC plates for Eibach Pro-Kit?
98GTnSC
as the title states im just wondering if i order the Eibach Pro Kit if ill need to get CC plates also. i know id need them for sportlines but idk about the pro kit. thanks
2slo95fiveoh
Lawrence, Kansas
C/C plates would be a good idea just for the ease of setting your alignment so you don't wear tires or experience any drift/pull to one direction.
As far as a necessity, I ran the prokit on my car without c/c plates for 3 years with no problems.. Camber and Caster were both in spec,
so it didn't wear a tire, and didn't pull. That being said your luck may differ. Getting a quality c/c plate like Max Motorsports now, would benifit
you down the road, in case you decided to upgrade to coilovers etc...
JiMi_DRiX
Tucson, AZ
My friend who does front end/supspension/alignment work says there is a way to modify something? So you dont have to get CC plates. I'm assuming it allows for extra travel to get the alignment straight. When I get mine done, I'll try to take pics and get more info.
2slo95fiveoh
Lawrence, Kansas
The factory plates are spot rivited onto the inner fender. Drilling out these rivits allows the plate to move freely and get some movement
out of them, but not nearly as much as aftermarket plates do.
JiMi_DRiX
Tucson, AZ
That is probably it. My friend has been doing front end work for yeaaars, he's an older dude. If he says it works, I know I can take his word for it. I will hopefully get all that stuff done in the coming month. Wheels are on order :)
98GTnSC
so does anyone know if ill need CC plates for a Prokit? prolly gonna order the spring in a few weeks and need to know if ima have to dish out for CC plates also
JiMi_DRiX
Tucson, AZ
Whats the deal with the ISO's? I was going to replace mine, but then I'm reading that some of you guys take them out. Doesnt that cause noise in the suspension or something "not good"?
Really the right way to do it is to get CC plates, if you don't want to spend the money on then now just get them down the line.
98GTnSC
well ill try it with no CC plates. then ill get them if the shop thinks i should get them to get them adjusted properly
another option is, you could use CC Bolts..
i used them for 2 years they worked great, until i got my MM CC plates installed.
