SN95 LED Gauge Cluster
scott5
myrtle beach, sc
Re: HOW TO: SN95 LED Gauge Cluster
White_5.0_GT said:
nice thread trey...i'll be doing this asap...but, i have a autometer water temp gauge that shines green...anyone know how to change that to blue so they would match?? do i just order a blue LED or what
you can call up autometer and get a blue sleeve that would go over the light in the gauge
95KBGT
Ok to answer your wuestion about the needles...
WHen i had my ranger this is what i did, not sure if this goes the same for mustangs but im sure it does.
You have to pull off the needles, use 600 gritt to sand down the back side of the needle (side that lays close to the guages) thats the part thats orange. then buy some transparent paint (which ever color you like you can usually find it at a model store, or walmart) and paint the back side of the needle where you just sanded.
Only down side is, you have to re calibrate your cluster. and thats not fun. Once those needles are off its tought to get them back together. I believe they may make a tool to help you out tho, not sure.
T
TxCobrA98
sounds cool Paul but i dont think i want to mess with all that.
i need to get off my a** and have you spray my 3rd brake light...
White_5.0_GT
oh thats not bad...did you do this for gauges you have too?
916_5.0
cntchds said:
916_5.0 said:
Thats what i was afraid of. ANyone know where we can buy the needles?
Interesting. I'm just curious as to what color you would swap them for? Orange seems to set off very nicely with the blue background. The contrast makes it very easy to see.
I was thinking red would look pretty nice or if i could get some new orange ones that are actually orange it would look nice, i wa thinking about doing this cause mine are faded and look yellow now and i dont think it looks very good.
Ok i thought i saw something on here a long time ago about painting the back side of the needles to change the color wasnt sure though. THe whole recalibrating thing sounds like a PITA.
brwillms
forgot about the old bulb rubbers
I dont think I saw it in there, but you gotta make sure you have the 5 led wide angle leds, otherwise you will have dark spots in the cluster, and really bright spots.
rgs
can you link me to the exact ones?
brwillms
Figured out that the clock uses what is called a seven segment LED display. Now if I can just find the right part in the right color. I'll keep you guys posted.
rgs
do you have any pics of your gauges? i want to know exactly what mine will look like with those exact bulbs
brwillms
I'll take some when I get home from work.
rgs
awesome, thx!!
brwillms
Well, my digital camera is a complete piece of crap. The pictures did not turn out well. I'll try again tonight.
T
TxCobrA98
updated my how to with after shots.. finally got around to doing it. couldn't get shots from inside though because it was cold and i had to have the lens opened for a bit to get the lighting.. i didn't focus it to well either, sorry! i was just trying to hurry...
brwillms
Here are two pics I was able to take with my cellphone. Quality is not very good. Guess I'm in the market for a new camera. Anyway, there are no hotspots with the bulbs I listed. There is even a slight color variation between the inner and outer rings of numbers. This looks really cool.
[attachment deleted by admin]
brwillms
I just looked at Trey's after pics. My lights appear to be a little more blue and the needles are just as visible. Hope this clarifies some things. I have a premier aftermarket stereo with blue illumination and they match it very well.
Nice job Trey.
T
TxCobrA98
mine are about the same color as yours in real life. mine are a bit more brighter but im thinking its because the white background?? idk
mine aren't as GREEN as they appear in the pictures though. i just had my lens open for a while and it sort of came out green.
sk8inrj1
Does anyone know if this mod will work on a 1994 cobra?
Bjp691
