Speed Cal Help
MustangMatt96GT
Well, my speed cal doesn't have the little red LED light lighting up when driving. It has power, and the fuse for the Cig lighter isn't bad. I just replaced the Speedo gear, because my speedo was notchy and not smooth. Well now the speedometer doesn't work. I noticed while going down my street, I pulled it back up the street, and took another car. Since it has snowed, I have not driven it. Do you think that its possible that the Speedo Gear isn't completely in the tranny? Any other thoughts?
scarface
you would notice if it wasnt in all the way. Contact Dallas mustang to help on the speedcal issue, they have a subforum on here in the vendors section.
Jrgunn5150
Mine wasn't powering up, so i got down there, unhooked everything, hooked it all back together, and it magically worked?
MustangMatt96GT
well it could be that, the connections seemed to slip, and i had to hold them in place to connect them.
Jrgunn5150
and you are tapped into your power point, or cig lighter, and it works normally?
MustangMatt96GT
yeah, i called Dallas Mustang on Friday. I talked to justin. I have now done what he has said, I will try and call him tommorow and see if he can get me another underwarrenty.
