Spring rate Question
Randy
My 95 gts 302.. Is about to get a new K Member after the Holidays.. I am thinking of going with a Team Z chromyl kit with coil overs and bump steer http://www.teamzmotorsports.net/product_p/tzm-cmkmk-94-95.htm I just am wondering what you guys would think a good spring rate would be..? Great roads here in Pensacola no bumps or potholes. Looking to get my car into the 10 sec range with 'in the next year. ( boosted 331 stroker ) currently have eibach lowered on front and rear...
Win
Kennesaw, Ga
i had a 14" 300lb and my old 347 was in the high tens....
i had a steeda comp 250lb rear spring on there.
well do you want a drag race spring rate or a good street/handling spring rate?
This ^
If you're looking for a good handling rate, Team Z doesn't offer anything.
According to the link you posted, the stiffest they have is 200lbs which is still pretty soft.
Win
Kennesaw, Ga
300 is a good spring rate then.. 150 is more drag spring... Then a 475 is more auto x track racing
Yup. I'm running 300# springs right now. They're very street friendly.
Randy
Randy
Sweet... Thanks...I will have to see if they offer a 300 plus on the rate if not the search goes' on .. I am looking to keep it under $ 1000.00 for the K member kit.
Win
Kennesaw, Ga
Just look and look... My old coilovers front and steeda rear.. I was only into it 225 bucks then add on another 225 I paid for my bilsteins on all 4 corners... You can easily find k member and all to easily under 1g
Just keep in mind you want to match the front spring rates with the rear, 300 may be hard to match without rear coilovers also.
Win
Kennesaw, Ga
Mine mated amazing with my steeda comp rears...
300 front
250 rear
rode amazing and actually handled like it was on rails.
mcglsr2
Orlando
I guess I won't be much help since I haven't installed them yet, but I've got 375 lbs for the front coilovers, 225 lbs in the rear coilovers (with a panhard bar). The car is a track car. I'm installing them soon.
300 front
250 rear
might depend who you ask then, my rear springs are 275-300lb-in and it was suggested to me not to go over 250lb-in coilovers in the front.
95opal
More of a good street handle.. I'll street drive it, more than at the track.
If that's indeed the case a 300-375 is fine upfront. The higher the spring rate the stiffer the ride will be. A 250 rear wil also be fine outback. Don't know if you looked into team z autox k-member its lighter along with some added bracing. Problem with the kit your looking at is its 100% drag oriented, no real spring rate for the street. If you switch up and go with there autox k-member and a arms, you can then look to maximum motorsports for there coilover setup which is by far one of the highest quality kits out there. All in all it will probably come out to the same price. If your on corral PM Art over at jdsperformance he gives great discounts on both MM and team-z stuff, cant beat his prices or service just a great guy to deal with.
Randy
Randy
I have no clue to what my rear eibach springs are rated... I just got the money hole 3 months ago... But I did notice when I put on new bbk gripper lower control arms and poly bushings in the stock upper rear, the car sits a bit higher in the rear. plus I put on rear top shelve monroe shocks and struts from local auto parts store... was hoping it would settle down but it hasn't .And I actually pulled out aluminum rear lower control arms and am replacing the bushings and putting them back in when K member gets installed. And hope it will set back down about a inch.. Plus I am going to get adjustable upper rear control arms that's gonna be another dilemma.
Randy
Randy
Thanks .. I'll get on that this weekend and check.. I want a 300 plus rate also from what ya all recommend, more street friendly. Thanks for your time
EdgarR213
