Springs and shocks/struts
tazmanhawaii
Ok, I'm in the process of changing by stock springs to FRPP B springs. My question is this, I heard that I should use FOX Stang shocks and struts because they are shorter then the SN-95 pieces? Car is a daily driver, I didn't want to go super low, looking at maybe doing the SCCA cone crushing thing once in a while, so my main reason in lowering it was to get rid of the 4x4 look and get a bit better handling than stock. The B springs lowered the rear about 3/4 of an inch and the fronts are rated at 1.2 inch. Thanks in advance.
2slo95fiveoh
Lawrence, Kansas
You should be fine running SN95 length Struts/Shocks... Using Fox length Struts is only benificial when you are slamming the car,
1.5+inches, or some coilover applications.. Unless you plan on lowering your car further down the road, I would stick with the
SN95 stuff. I have Eibach pro-kit (appox the same lowering as B springs) with SN95 Tokico blue struts/shocks for 5 years now, with
no problems.
