Spyders Engine Rebuild - 302 to 331
Spyder
Well, I still need to break it in a bit and adjust the timing, so for the moment it feels okay, but I'm gonna tune it a bit tonight and maybe rip on it a bit.
Hicks
Arn't you sapposed to go 500 miles?
Spyder
Well, I have read a ton of threads all over about breaking it in. Most people say to make sure the pistons rings are seated, then rip it up. And most of the shops I have talked to break them in on the dyno, so ill be nice to it for a minute or two
Hicks
i just always heard the 500 mile thing..???
How do you know when the rings are seated?
Doc_G
Birmingham, AL
do those links not work for anyone else... all I get is some wierd russian looking text w/alot of squares... OMG WTF HAX???
Spyder
Usually when the engine stops smoking, that means the rings are seated. Plus, the general concensus is that they will be seated within the first few minutes of start up.
Hicks
Hmm........ i gues the 500 mile is just saftey then?
Ill probly ride mine alittle but ill wait till my 500 is up i dunno..
Im perinoid >.<
MeanGrn Gt
if the rings dont seat properly right away then they wont ever. You dont have to baby it for 500 miles. Main thing is to change oil properly
also the vids aint working for me either :dunno:
RIngs break in much faster than they used to.
Mine broke in on the dyno. (before it blew up)
The vids are standard .AVI format. you guys may need to update your codec.
Hicks
Meh.... I still don't understand. Is there like a certai thing you gota do right when you first crank your engine for the first time?
Spyder
From what i have read and heard from various sources, there isnt much you can do when the rings are seating.
Once you start the new engine, you dont want to rev it to the moon right away. And by the time you feel comfortable enough to drive it, the rings have already seated.
Basically when you first start it up just let it idle until it stops smoking, then your rings are pretty much seated and your all set. Since we have hydrolic roller cams, there is no need for running it on jackstands or letting it idle for an hour or anything like that. Those are techniques for solid flat tappet cams, so they dont apply to us.
Well, we got the timing set at about 15*, and it is running real nice!! I havent done any full throttle pulls, but for playing around with half throttle, she pulls nice and hard.
Hicks
i just kindof figured like the Engine itsself would need to adjust and set in to... ya know?
I dunno... enyone else got eny imput?
Spyder
Yeah, the computer is alwasy learning and retuning some perimeters, but most of the major adjustments the computer makes will be made within 20-30 minutes of running.
Hicks
Ic, well thats cool. I'll probly still be easy on the car for a while. Just because im perinoid... lol
But i didn't know you could run it that quick..
i figured the crank would like break or something from not being warn in or something mess up??
Trickflow.GT
what kinda of harmonic balancer did you go with....50, 28? im doing my motor soon and im not sure what a 331 needs... :dunno:
Spyder
I have always been told that with any late model 302 based motor that you should go with a 50oz balancer.
I went with the professional products because it was affordable
If money isnt too tight, i have heard alot of good things about the romac balancers
jeanfltns01
