Stealth Mare: from the begining
B.mad
Preferred Vendor
SoCal
I think what B.mad is saying is, the sidewall on tires running 285/40 on a 9" wheel is going to flex. Typically you want to go 275/40 max on a 9" wide wheel. Although "racers" will run 255/40 or even 245/40 on a 9" for that stretched out look and better turn in.
Pretty much
Sent from my SM-G930T using Tapatalk
codfod
SoCal
Not sure what tires you're looking for specifically but the place I go to is Discounted Wheel Warehouse in Fullerton, they're usually 20 or 30 bucks cheaper per tire than anywhere else on the Nittos I tend to buy.
B.mad
Preferred Vendor
SoCal
do they have hankooks too? i need me some RS3
Frank.JD.Perez
Pleasanton/Hayward, CA
Latest photo shoot
Frank.JD.Perez
O2 codes p0141 and p0136
Hey guys I have these 2 codes being thrown right now on the Mare and I wanted to get your opinions. I run MIL eliminators on the car because of the X pipe and I've had multiple occurrences where I've found the plugs dragging on the ground. The 2 codes are for the 2nd passenger side sensor. My question is do you think I need to replace the o2 or replace one of the MIL?
Frank.JD.Perez
Those wheels are freakin' tight! Stance is perfect too.
Thank you good sir! It was hard the come by a real set of FR500s, I want the rear to be lower and the 35% profile made the wheel gap bigger than what I wanted so now it's a race *pun intended* to get a new set of 275 40 18s up front and back. My front wheel gap I could only stick 1 finger in it now I can fit 2...
jeffs mustang
