T56 Magnum Swap 99-04 GT
96blak54
In the shop
Oh yes! In my case it found me, only tho....i havent found the money for it! Its really sad too cause i need it in my life!!
Are you thinking about getting it? Because cool factor shoots straight up to 100!
doggiedoc
doggiedoc
Oh snap! I need to find a bellhousing now.
Will an 03-04 Cobra work? Or another?
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
03-04 cobra bell housing will work or you can get a quick time bell. The quick time bell is a lot more hassle because you have to take measurements and make sure the trans input shaft is centered on the crankshaft. Sometimes you have to use offset dowels to make the bell align correctly. @white95 just went through this. It’s a hassle.
white95
Apex Junky
Admin
Prairieville, LA
Yes. It’s a pain in Williams neck to use the QuickTime bell housing but it is quite the unit. You’d be hard pressed to destroy it.
*note*
That driveshaft comes with 1350 u-joints and the rear flange uses the large bolt pattern. Assuming you still have a solid rear axle, order this rear flange to retain the 1350 u-joint but work with your 3.5” companion flange:
https://www.sonnax.com/parts/4475-flange-yoke
doggiedoc
doggiedoc
Thanks! I found an 03 Cobra bellhousing on eBay. I may pull the trigger on it if I don’t find one cheaper soon.
doggiedoc
doggiedoc
Now I just need to commit on wide ratio or close. I’ve got 3.73 gears so I might go with the wide. But I really like the super low 6th for highway in the close. I wouldn’t mind hearing y’all’s opinions.
white95
Apex Junky
Admin
Prairieville, LA
I have a wide ratio box with 6th gear being .50! I bet it’s gonna be nice on the freeway.
doggiedoc
doggiedoc
I thought the wide ratio had a 0.63 for sixth. 2.66 first.
joe65
hey i just saw a t56 for sale on FB marketplace for $1900. Just saying.
doggiedoc
doggiedoc
Ya. But I’d still send it up to Tick Performance to get the upgrades.
doggiedoc
doggiedoc
Ordered the driveshaft and Sonnax flange just now. Thanks for the heads-up!
doggiedoc
doggiedoc
I just got off the phone with Tick Performance, where I ordered the customized T56 Magnum - they only expect 2-3 weeks to be ready. Just placed the order this morning. So maybe .....
alleghenyamerican
