tb and intakes ?
Snowed
Will a stock tb fit with a tf street heat elbow adapter as far as bolt alignment, or is the tb to small, itll be just temporary till i can afford a 65mm one
97 king cobra
yes. all of the flanges on tb's are the same from 60mm to 75mm. So if the elbow will fit an aftermarket 75mm it will fit the stock one as well and any size in-between.
det_riot
Dearborn
Truth, only the internal diameter is different. The opening is the same size. I have the same set up as the op and ran my OEM throttle body for a few weeks until I picked up a 75mm off of a local forum!
Snowed
det_riot how did it run with the stock tb, notice much of a gain when you switched?
hottwheels04
I have a 65mm bbk throttle body for sale hit me up $100.00 shipped
det_riot
Dearborn
I also had bad wires after I swapped the Intake. Once the plug wires were solved I noticed a mild pick up in the lower end of the power band. After I put the throttle body on, I felt a much quicker throttle response than I felt with the stock throttle body. IMO the throttle body really helps you to feel the intake swap.
Snowed
You running the E cam with yours, how much diff than stock as far as seat of the pants?are you running with or with out heads
det_riot
Dearborn
Right now I'm w/o heads(been searching though) and the e cam has been in my car since I got it. Its definitely much quicker than before. Pre intake and throttle body I could barely chirp second on the street, not I can break it loose in second
