Teksid Motor Questions
ponyboy88
Theres a guy in my area selling a Teksid (96-98?) Cobra motor with 5k on it for a great price.
I would be looking to swap the motor into my foxbody, and was planning on doing a 351w stroked to a 408 or 393 going either n/a or blown. Its completley a streeted car, will probably never see the track. Power goal is 500-600 rwhp.
I wanted to know some more about these motors, were these 4v or 3v heads, how good are the stock internals and how well does it handle boost.
I was thinking a Kenne Bell or paxton blower, can i see these numbers on the stock short block? and intake?
Thanks for any and all info you guys can give me,
uncltrvlnmatt
Pa.
The 96-98 Cobra use the 4 valve "B" head. The 96-98 are a higher compression ratio, I believe 10-1, and do not come stock with forged internals, accept the crankshaft. So they are not compatable with big boost applications(more than 10psi)
The Eaton supercharger off of the 03/04 Cobra will not work on the 96-98 engine, and it is extremely expensive to do the swap. The 99/04 Cobra/Mach1 uses the "C" head.
Factory ratings are 305hp and 300tq at the flywheel. My 97 Cobra is putting down 258rwhp 250rwt on a mustang dyno and is bone stock. The blocks themselves are quite strong and if I am not mistaken can handle 800+hp.
modularfords.com has an entire section devoted to modular engine swaps, and they are very helpful. When I run into potential issues with my swap that is where I go for answers.
ryeguy2006a
The teksid blocks can handle up to 1200 hp. They have six bolt mains and are extremely stong.
Traidmarx
they are very strong and as far as them being a problem due to having hypertectic pistons...i wouldn't feed too much into that...my best friend sprayed 175 shot on his 97 cobra for a year and a half.
Canaryonvskf’s
