Temp Guage
matholland
I have a suntune temp guage and I was wondering how I install it....can I tap into my wires behind my guage cluster?
det_riot
Dearborn
is it mechanical or electical? I just hooked up my autometer gauges yesterday. they only needed power and ground becuase they're mechanical. On a mechanical gauge, I tapped the blue/red wire on the white connector for power and the black wire on the white connector for ground. That hooked them up so that the backlights will turn on with the headlights.
matholland
its an electrical guage has some brass fittings, and on that a wire connects too (the one that screws into the intake...has the spot for a wire...i was hoping i could just tap into my stock guage instead of running wires...and it doesnt have any wires with it.
DFG_magic
Kennesaw, GA
You can't use the stock sender/signal for that gauge. You'll have to use the sending unit and hardware that came with the gauge to make it work properly. Just do it right and use what came with the kit.
matholland
so the stock guage will no longer work at all right? I have the exploder intake if that matters.
toyman
It will if you leave it attached. If you do that you will have to mount the new gauge sending unit in a different location.
Adam95GT
Soooo you bought a gauge and you want to use the stock sender.... do you like pretty lights???
You should stick the after market gauge in the stock location because it is the most accurate. You can buy a new thermostat housing and put the stock gauge in there. $8
(Note in these pictures i put my ect sensor in the housing)
matholland
ahh so the one that came on my gt40 intake, and i thought it was for a fox body because it had the plug at the top and mine didnt. Another question. Where would be a good place to mount my new guage?
det_riot
Dearborn
Adam, does your gauge bezel fit like shit?? I've got the same one and it fits like garbage lol
Adam95GT
det_riot said:
Adam, does your gauge bezel fit like sh*t?? I've got the same one and it fits like garbage lol
It fits well for what it cost me.... Free...
Translation: Fits like crap, did you install the metal brackets??? Im just not happy with the hole cut for the defroster.
Addermk2
Adam95GT said:
Addermk2 said:
Oh man.. I cant wait to get my black interior installed!
NICE!
I got lucky, i found a guy parting out a 94 cobra, just like mine. Got his entire interior (airbags, seats etc) plus his entire a/c system (mine has been removed for years), plus various other crap I needed, all for $675 and an axle housing!
det_riot
Dearborn
metal brackets? no i got mine off cl for 20 bucks so i didnt know it needed any brackets. what do they look like and where do they go?
