TFS stage 2 cam
rob10s2
what do you guys think of the tfs stage 2 cam? i was thinking that cam, afr 165 or 185's, and a tfs track heat manifold for my top end. will i have any low rpm torque? this is a 5 spd car by the way
slowjunk50
The stage II will probably not clear the pistons. Trick flow says it should if all of the tolerances from ford are in the middle but if they are all on the plus side you are going to have interference issues.
rio94
does anyone know if the stage one will be ok with 1.7 rockers :dunno:
slowjunk50
Not for sure. I think it will but I would call TFS to make sure. I liked my stage I alot. It was a fun street engine with that cam.
R
rob10s2
how did it sound? nice n gurgly? i want something i can run with an slp exhast that will make ricers cry when they hear it.
fastNA 95GT
no trickflow cams or motorsport cams was told they are better used as baseball bats. go custom grind youll be much happier flowtechinduction .com
had a stage 2 tf cam car was slow sbut sounded good.
165 302cid to 310ci 185 for 331cid and up and must have a piston for 2.02 valve relief.
