The Ultimate Suspension Guide
Status
Not open for further replies.
RedTwilight
Roxboro, NC
Factory stock for now. But that'll soon change. I've already started gathering parts.
Plans are
Rear:
'03 Cobra IRS with FTBR delrin bushings, bumpsteer/ toe link kit, and modded FRPP diff cover.
Bilstein shocks
H&R Race Springs or go for Maximum Motorsports Coil overs
Front:
'03-'04 Cobra front lower control arms
Steeda X2 ball joints
Global West Del-A-Lum bushings
Bilsteins struts
H&R race springs or Maximum Motorsports coil overs
MM 4 bolt caster camber plates
MM bumpsteer kit
MM sway bar end links
MM K member or Team Z autocross K Member
* MM front lower control arms if/ when converting to coilovers
Other:
Stifflers full length subframe connectors with jacking rails and matrix braces.
Stifflers tubular transmission cross member
Stifflers spider brace
6 point cage
Nuttinbutcrumbs
Nuttinbutcrumbs
Between the Red and the Rio
Plans are
Rear:
Bilstein shocks
Front:
Bilsteins struts
MM bumpsteer kit
Other:
6 point cage
Road course car?
Don't Sext and Drive.
g36 monkey
Orlando, Fl
Impressive list.
My red car has the whole MM k member setup, and mm rear coil overs. still working on the panhard bar and torque arm and a built 8.8 with 9" housings.
I'm not sure I understand the thread? Are you asking for the "best suspension"? Or just a list of what people are running suspension wise?
suspension setup is under that cobra hood?
Wut
absolutely nothing under my cobra hood that is not stock. I mean unless your going to go 150 mph then why do you need it to go to/from 711? Just some stick on hood pins on the top for the look but other then that completely stock.
g36 monkey
Orlando, Fl
I only ever see speeds in excess of 200. My car is in perpetual motion.
So are cobra hoods the ultimate suspension upgrade?
I get that the nostrils are used for extreme ventilation and cooling, and that the hood is made of reinforced aluminium to reduce body flex, but are they really that great?
Nuttinbutcrumbs
Nuttinbutcrumbs
Ha! Yes....
Disregard the failed attempt at a joke w the cobra hood. What are kind of suspension do y'all have?
I have a very street friendly setup.
- Strange front coilover kit
- Strange 10-way adjustable struts
- QA1 10" 300lbs springs
- J&M caster camber plates
- Revo Technica camber kit
- SVE rear lowering springs
- Strange 10-way adjustable shocks
- UPR rear coilover mounting brackets
- J&M lower control arms
- Rear cobra sway bar
Planning to get tubular a-arms and a second attempt at a rear coilover kit for the holidays. Then next year a 4 point cage custom fabbed into a 6 point.
I've wanted subframes for the longest time but have come to the realization that will never happen because they would be a pain in the ass to deal with scraping everywhere.
Other than that, I don't have much planned for suspension. It rides nice as is and won't be taken to anything more than a road course for recreational activities.
Y2k carbon fiber cobra R hood
Ridetech dual adjustable shock waves front/rear and ridetech E3 controller with automatic ride height sensors
Steeda adjustable sway bar in rear, non adjustable up front(bump steer kit)
Steeda Billet Fronts sway bar mounts that I had anodized black
Ridetech Strongarm rear control arms
MAximum motorsports Front control arms
Max motorsports K and then the spintech full length subrame connectors.
Its really simple and yet it isn't, I want it all... I want to be able to have the adjustability to tighten it up with a few clicks and take on a drag strip or a road course and enjoy an afternoon/evening while not fearing the need for a trailer or to be beat up on the ride to/from. I want to take it to a show and drop it like its hot and ride in comfort to/from while fearing no speed bump or curb. Some say you can't have your cake and eat it too. I think its just a really expensive cake if you want a bite of it and be able to enjoy everything.....
Nuttinbutcrumbs
Nuttinbutcrumbs
Weekend street car. Nothing fancy but it's handles better than when it was new and well enough to get you in trouble on a public road. The ride is firm but it doesn't beat you to death. I need to address the rear end still, I have a lot of azz wag going on. The plan for the rear is to replace the old rubber bushings in the uppers with new rubber bushings in conjunction w a set of aftermarket lowers.
As of now:
KYB non adjustable shocks/struts
Ford racing b springs
Standard length weld in sfc's (big improvement)
Refurbished front-end using Moog "problem solvers." I have no issues with them with my modest drop.
RedTwilight
Roxboro, NC
The thought crossed my mind to go this route also instead of coil overs. But I didn't want to deal with the air tank, compressors, and airlines, etc. that is involved with an air kit and the extra weight that comes with all that.
Do you think an aluminum tank, compressor/ bags and the lines weighs more then the 4 springs? Pretty sure I saw somewhere it was not.
evilcw311
Most Evil Member!
Louisville, KY
They pretty much balance out. In all actuality your shifting more weight to the rear and lightening the front.
Status
Speedymac
