96laseredcobra
Will this cause the clutch pedal to vibrate in gear and not in gear while pulling to a stop?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Gave me a good chuckle.To use the tool you'll need to take the flywheel off. Im going to warn you though, the tools are not that great with our pilot bearings. You will be much better of just using the bread and you will save yourself a lot of headache.
Sent from my LGL22C using Tapatalk
He was being serious about the bread lolGave me a good chuckle.
It's the same idea as using grease to get it out. You pack it in and use a bolt and hammer it into the bearing and it'll push behind the bearing and the pressure will eventually push the bearing out.Vibrate or pulsate?
if your clutch pedal is pulsating with it in gear and driving down the road, then the TOB is constantly touching the pressure plate springs, this will cause premature TOB failure.
Alright... What is it with the bread? i have heard some amazing redneck engineering stories, but never one about bread and a pilot bearing.
I imagine some would use bread instead of grease for an easier cleanup.
Sent from my SM-G900P using Tapatalk
Thanks for all the help. I actually have a buddy who is a lot more experienced than me that's going to help me drop the tranny and do all of this.Bread is a great method to getting the PB out. Op just swap out the TOB and PB. All of this is pretty simple aside from taking some time pulling the trans. Very sure that your TOB is failing but the PB could use a replacement as well. If you have any questions on how to remove the trans or anything we can help you on here step by step and you can have it fixed in no time. Buy a Ford racing TOB and PB as others will fail quite a bit quicker.
