MustangMoser said:
Lee12609 said:
when the tie rods are mounted forward of the spindle on acceleration the front end lifts, pulling the front of the tires INWARD (negative toe)
when the tie rods are mounted rearward of the spindle on acceleration the front end lifts, pulling the front tires OUTWARD (positive toe).
are you taking about lifting the tire off the pavement? I'm a technician too and I'm gonna wave the bs flag on this, if the tire is on the ground its ALWAYS gonna go toe out from being pushed, if your alignment is right at the moment.
On 3 Performance is 100% right on this.
LOL, i'm not talking about doing wheelies....
here is a scenario for you and ON3... you first have to realize that when a car is moved from a stop the weight is transferred to the rear of the car and the front end "lifts". this lift changes the lower control arm and tie rod angle correct??? essentially the same as lifting or lowering a vehicle.
now lets say you put a jack under your oil pan and lift the front of the car 1", this pulls the tie rods DOWN, which pulls the front of the tires together (positive toe)... now do the same thing to a car with tie rods mounted rearward of the spindle and the tie rods are pulled down bringing the back of the tires together (negative toe)...
for this same reason an SN95 that is lowered will exhibit negative toe....
i believe you 2 are talking about cruising and i am talking about accelerating that is where the confusion is coming from, so my fault if you are. in which case yes the front wheels are pushed rearward causing negative toe if the alignment isnt set with some amount of positive toe......
