tires rubbing
aarons_4six
i just put 285/40r18's on my saleen wheels, car is unlowered. well it rubs on the inside when i hit dips on the interstate, then i just came up the drive way and it sliced the sidewall curve tread some. maybe a set of wheel spacers? or roll the rear fender/lip?
I would assume you mean the outside sidewall and not the inside, putting a spacer on it will bring it further out and even worse wouldn't it?
what brand tires? I have heard that the are a little different from each other.
Larius
The funny thing about factory springs is they give up more travel than lowering springs so some times its better to lower it to give a firmer response. If you are wanting to keep the car as is I would roll the fender lips and hammer the inner fender wells in to give it clearance.
A
aarons_4six
yeah i thought about hammering the lip over. and as far as lowering it i plan on it, i have the springs just want to do all the suspension at once. i need shocks, cc plates, rear control arms so i can ditch the quadshocks. i may pull the wheels and hammer the lip tomorrow. maybe tape the exterior and use a wooden block as a backer?
JoshHooten
Hiram, GA
mine is lowered with 315/35-17 and it cuts into the tire if i turn sharp or at an angle i have 10.5 deep dish bullits in the rear with almost a 1/4 in spacer and my fenders need to be rolled and saleens don't have much offset do they i would think some spacers but i have never dealt with saleens although i would like to
A
aarons_4six
they are 9.5's not sure of the rear offset, my dad showed me that eastwood has a fender roller for 269, looks like a quality piece! btw they are goodyear eagle f1 supercars
JoshHooten
Hiram, GA
i would def say roll the fender if possible i have nitto555s and you can see where the fenders cut into them like a knife i need em rolled bad and i love the way the f1 super car tires look i bet they look real good on saleens
A
aarons_4six
it looks very aggressive, the wheels are powdercoated mirror black with candy purple faces. really sick lookin car now. ill go do a photoshoot soon, my dad n i are putting our cars in a show weekend after next, so maybe then at latest.
if you are cutting the outer edge of the tire on the fender I think I would tryit with out the spacer to see if you need to modify the fenders and buy a tool to do so rather then just take the spacer out?
Venom351R
Maine
Roll the fenders, adding spacers will just cause it to cut the tire in a different location if nothing else is done to it. Must be something w/ the back spacing of those rims. I run 17X10.5 Cobra R's in the rear with 315 Nitto's and I dont rub anything, not even on the quads when I still had them on
Untame-d
I did my fender lips myself without a roller.. used a body hammer, vicegrips, wood, cloth.. very carefully. worked good.. only took about an hour.. problem fixed.
A
aarons_4six
what all do i need to ditch the quadshocks? and where will i see an improvement or loss in suspension?
