Tourqe for Temperature sending unit please?!
9646gt
Ok I bareley tightened my sensor and it cracked my lower intake manifold. Maybe it was jsut brittle after 189k? So what is the propper torque and sealent to use on this sensor to prevent this from happening on my oem replacement that's coming?
Paul
Use white silicone. Snug is plenty. You cranked on it too hard - these are not load-bearing, and don't need to be super-tight. Just enough so the water doesn't leak out.
Paul.
if you dont tighten it enough: water leaks out and you tighten it a little more...
if you over tighten it: shit breaks and you have to buy a new manifold. lol.
better to start soft opposed to crankin' on it... :)
9646gt
No plastic cross over. This is a 5.0 manifold not 4.6 :) BTW the proper torque is 8-18 foot pounds. So I should use some like water pump/thermostat rtv sealent instead of one layer of teflon tape? It only had 3 or 4 threads in when it cracked. It wasn't even close to being in as far as the factory one was. Odd.
