Trans. out of the stang.
95DarkGreenGTS
Bossier City LA
Well I ripped the 5 speed out of the stang tonight. The piliot bearing was making noises. So in the morning im going to change the piliot bearing throw out bearing and rear main seal. I would change the clutch but just had that changed less then a year ago. Its actually not that hard to get the tans down. now it might be harder to get it back in there LOL
94kingcbra
Well what was the reason for replacing the rear main seal? Was it leaking? If so, the friction material on you clutch might be contaminated.... just my $.02
snakebit95
Getting the transmission back in by yourself can be a PITA. Try to find a friend to help. If I pull the tranny with the engine still in the car, I try to get the car as high off the ground as possible via jack stands. While laying on my back on my creeper, I have a buddy lay the tranny on my chest and then I roll under the car. I press the tranny up (like a chest press) and stick it in the hole. It will take both hands to hold it. Have your buddy start the bolts. What ever you do......do not use the bolts to pull the tranny in. You need to get it pushed in by hand. If not, you take the chance of damaging the input shaft or pilot bearing.
Oh yeah....make sure you have a clutch alignment tool. You will need to align the clutch disk before trying to install the tranny. It is not that hard if you take your time and have a friend to help. Good Luck!!
95DarkGreenGTS
95DarkGreenGTS
Bossier City LA
No the rear main seal is just there so I figured I would do it bc knowing my luck it would start leaking a week from now.
Also I have the alignment tool so hopefully all goes well. I plan on putting it back in the stang today!
