Went to the track
94 DropTop
Well, I took the stang out to the track. I didnt do as well as i would have liked but I hit 15 so im still smiling. Keep in mind this a vert, auto, and on bald tires(past wear bars). Best 60ft was 2.2984(the rest were around 2.4. And a best E/T of 15.8763. My next mods are going to be Tires,4.10 gears,U/L Control arms, and SFC. What do you think I would be running after these? I can also easily take out an extra 100+ pounds. Thanks for the advice. I will not be putting nitrous on the car, so dont suggest it.
Demolisher
Ok well u should be doing much better in my vert keep in mind auto also i hit a 15.2 stock and i knew there was more left in the car so somthing must be wrong make sure ur car is running right and go back on good tires TIRES MEAN ALOT
94 DropTop
i put god knows how many post on my car is not running right and nobody agrees with me. my buddys coupe ran a 15.2 stock also. The fact that im runing 18's dosent help eather.
quickstang_1994
Cross Anchor, SC
Sorry I did see your other post but borrow or replace the MAF sensor mine never though a code when it was bad a acted the same way (it took me a year to fix). If its not bad take it back there for you want lose money, cleaning does not always work. Where are you from? Do a correction at modular depot and the weather is at weather underground(go to history for the time you ran). Dont upgrade till you get the car fixed.The 18's are fine all of my mustangs have 18's. Your 60' is right for a stock car and with the auto its not driver.
94 DropTop
im from kansas what do you mean do a correction at modular depot?
94 DropTop
i dont have a sensor I can borrow? my other friends have 96+ stangs
quickstang_1994
Cross Anchor, SC
http://www.modulardepot.com/density.php
Its to help compare because you may live where weather is bad or alt.
Go buy one from Autozone if it works keep it if not take it back.
94 DropTop
i work at autozone. i just bought one and kind of rigged it up dont really feel a difference though.
RevJon
