what should it run
5literstang
just wonder opinions on what some of you thing a 94 gt should run in the quarter with these mod?
TFS twisted wedge heads with valve spring upgrade, holley systemax II intake manifold, AFM N41 cam, 24lb injectors, 70mm throttle body, 1.6 rr, mac long tubes, off road h pipe, mac cat back, AFM velocity 95mm Maf, msd 6al, deleted ac and smog, 3.73, AFM power pipe, 5 spd, and slicks
Stangbangin
you basically have my set up. give or take a bigger intake and unsure of your cam specs. I'll run 13.1's all motor on DR's ALL DAY I'd be in the 12's with slicks. with a 150 shot I've ran a 11.97.
stang94X
what are the specs on that cam
Stangbangin
I think regardless on cam specs he could be in the mid to low 13 second range given he's not running a stock cam.
