wheel spacers??
95cvgt
just wondering what size you sn95(94-95) guys are running? i want to keep them out a good bit but no to far and i definitely dont want to leave them to far in either. im currently running 245/45/17X8 all the way around until i get the new rims later this summer. i was thinkin about goin with the 30 to 35mm. any good results with those? i will be ordering the spacers along with sportlines and cc plates. its going to be such a drastic change in the looks, i cant wait!
thanks for all the help in advance, you guys are great :eek:ccasion14:
eliyarbrough
Nocona, TX
I have 17x9 Faleen rims. I also have 275/40-17. I have the Pro-Kits on mine. I bought 1" spacers for mine! Looks just right. I am not sure what you will need with your 17x8 & 245's, though. You will get a reply of what you will need, maybe 1.5"? When you do, buy from these guys:
They are cjbargins.
Here's their store page:http://myworld.ebay.com/cjbargins/
I got mine for $61/shipped. I don't really care too much for eBay now. I only buy from sellers guys on here have bought from. There are quite a few members on here with these spacers!
95-stang
I have the stock GT 245x17 rims and used 1" spacers on the rear to kick them out a bit and it looked tons better.
dutch
Whenever I get time to put the longer studs in the rear axles, I will be having 1/2" spacers in the back and 1/4" in the front. Should be perfect.
5.Woahhh
With 8in tires you could run a 1.75in spacer. I have 17x9 on mine and the 1.25in spacer I run makes the tires sit perfect with the fender.
LAFENATU
Just make sure you get the spacers that CONNECT TO THE AXLE.
All the other spacers are bad news.
Matt94GT
hubcentric. you can get the ones with the suds if your looking at a 1" spacer, they are good. if you get the plain spacers that just sit on your hub you will need longer wheel studs, that is for spacers that are around 1/8th-1/4"
97GT4.6
Colorado
yeah those look decent. At least they will be safe on your ride. 1.5 is alot though. with the same rims as your car has, i put 1 inch spacers on it, and it made a world of difference.
