Wheel Studs?
MustangMatt96GT
Studs
Which studs do I need? I think they are the Press-In .625" Knurl Wheel Studs with the part number 070-100-7703. Please help me out!! I need the 3 inchers to pass tech at the track!
19mustang95
PM Scarface, he knows the exact ones you need..i know you need the push in type, not the screw in, but i don't know the exact one.
scarface
Guest
MustangMatt96GT said:
Thanks man
It is the .625 Knurl 1/2" -20
ARP wheel studs FTW lol
sorry, I didnt see this thread. You seem to have it under control. just so you know, there is no direct fit studs for the rear, you will have to clean the holes up a bit to make them fit.
Moroso sells direct fit knurl press in studs for the front.
MustangMatt96GT
Thanks just, i have a buddy running these, and he didnt have to do anything but pressthem in by using some washers and a lug nut and an Impact. How would u clean them up a little?
scarface
Guest
you wont be able to just press them in, I had to use a dremmel tool and a sanding pad.
MustangMatt96GT
which bits did u use do u remember? I am retarted when it comes to dremel bits and i ruin most of them because I use the wrong ones! that scarface!
And yes I am a stud! lol
scarface
Guest
I used the round heavy grit sandpaper bit...the sleeves that are replaceable.
Jerry santos
