Where is my gas going?!?!?!?
stanger
Ok, amoung other problems my current issue is my car is only getting about 220 miles to a tank of fuel!!! It was much better before I installed the o/r h pipe. I do not have MIL eliminators as the used h pipe that I bought had the holes in it for the O2 sensors so they were installed. It has a new fuel filter, spark plugs, CAI, EGR. I also cleaned the IAC and it just seems to be getting worse with every fill up. I am running sea foam through it right now so would that make it use more fuel? Any suggestions are appreciated guys. $40 a week in fuel is killing me right now. Thanks to everyone. :BangHead:
bryand
wow, my stangs get 160 out of a tank, id be happy with 220, now i feel bad
Duff Daddy said:
I get about 300 to mine. Is there any leaks? Check engine light on??
me too... roughly 315 mixed.
I honestly think it might be due to the lack of cats, but thats an expensive fix if im wrong. lol.
bryand
id be so happy with 300, i might accually drive the things if i could get that
BII302
Fayettenam, NC
Check the rubber piece that connects the fill neck to the gas tank. Mine dry rotted once and was leaking a decent amount of fuel everytime i turned. Couldn't figure out wtf was going on till i noticed fuel leaking onto the ground when i was filling up one day.
Mean98GT
+1 on the dry rotted rubber piece. Left turns would cause me to dump a decent amount of fuel. And if I filled up all the way it would leak all the time.
be aware that you have to drop the tank to replace the rubber seal on the fill tube, so avoid fill-ups until you can rule that out, or fix it.
96redgt
Charleston, SC
^^^ Not exactly true. Its a pain in the ***, but you can replace it with the tank still on the car. I did. Took a while, but I did. I did have to loosen the straps a little, but not completely drop it.
stanger
stanger
Thanks guys and for the outside correspondence Chris. I will definitely check the fill tube seal as soon as this rain stops. 4" in two days doesn't do a leaking convertible top that needs to be replaced any good! Thanks again.
GDTrumbo
Nashville, TN
OP. If you are getting a CEL, which by all account you should be, the PCM is always "open" loop. This alone will drop your fuel mileage as all
of the pertinent sensors are turned off.
GT
stanger
stanger
My CEL comes on every night and usually goes off sometime during the day. I am currently getting the code P1443 and will be cleaning the valve this weekend as well as checking for the dryrotted fuel fill seal. I am currently running sea foam through the fuel tank, will that make it burn fuel faster?
