Which cam for my combo?
snakesonastang
This is my current setup. 342 with 185 AFR heads, 1.6 rr, RPM II intake, 10.5-1 compression, full exhaust upgrade, 2800 stall, 3.55 gears, and 6 lbs of boost Powerdyne. What I'm looking for in a cam is a nice idle and street manners. I don't care at this time for the biggest hp numbers.
These are the specs of the two cams that I'm looking at.
Lift .512/.512 .480/.480
intake 0.50 218 220
exhaust 0.50 224 226
LSA 114 115
XE 270hr Steeda 19
1800-5800 rpm range 2000-6000 rpm range
Out of these two which would be a better choice.
LAFENATU
With a stroker, I would spend the extra $100 on a custom cam. Get something that will work well for your motor. The cams you list are for small block 302's. You have a 342.
I would talk to Ed Curtis or Jay Allen.
Ed Curtis is an NMRA Champ as well as an engineer. He does wonders with engines.
www.flowtechinduction.comhttp://
Jay Allen also does great work.
Www.camshaftinnovations.comhttp://
Yellow94gt
Anderson Ford Motorsports... call them and have them grind you a custom blower cam. You'll be happy you did.
