Which way to face the pigtails?
BMAC96GT
Virginia
Hey guys. I put sportlines on my car over the summer and took all of the isos out except for the top ones in the back. As you can see from my sig, it has a little bit of a rake, so im gonna go ahead and take the isos out of the back too. When I put the rear springs back on, I faced both pigtails toward each other. I'm pretty sure this is right but just wanted to ask you guys
98v6er
Central Florida
Both of the rear pigtails should be facing the drivers side of the car.
BMAC96GT
BMAC96GT
Virginia
Thanks man. I kinda had a feeling that was the way to do it. And by the way, you have the best looking V6 I've ever seen! Looks better than the majority of GT's and Cobras on the site
yep both pig tails should definitely point to the drivers side. That would put the ends at the rear of the spring perch.
ReplicaR
Actually, I don't think it matters which way they face. If I remember correctly, both top and bottom spring perch are flat, so the spring should sit the same way regardless of where the pigtail points.
98v6er
Central Florida
No problem... thanks! :thumbsup:
