You could always measure them or have the shop do it to see the specs.
I'll put a digital caliper on it but that's about it.
Calipers wont do you any good. Even finding lift values and here is why. The follower is not on a fixed fulcrum like every other car manufacturered is. If the follower was a rocker, then yes...simple measuring devices can get you close. Now let me try to explain.
As the lobe swings around, the lasher keeps tention to the follower to stay on the cam lobe and valve tip. As the cam ramp swings in, the lasher will have to bleed down to its lock point. Now....some cam manufacturer take advantage of this by grinding the cam base circle smaller to allow a later valve timing event....utilize more of lasher bleed down rate.
Yes, I just stated the modulars have a mechanical veriable valve timing. From driving rpm to high rpm the lashers go into a bled out mode once rpm's are up, relying on the spring within the lasher to keep things together and depending on base circle ground off depends on bleed amount. Also lasher type alters bleed amount as well. This is why folks go with ford Gt lashers on the exhaust. A lasher designed for 5w-50 oil reacts different with 5w-20
I can go all day here, but really if you want I can check them out for you...no biggie!
Hmm, now I'm intrigued.
Or you could do stock dohc B head lashers
They bleed faster than pi stock and dont require much cost. Have to find them though. Scotty probably has over 200pc. Best part, you dont need Gt matching followers. Also to boot, you could solid lash the intake side for more performance. Move your compression up if you wanted too. These modulars offer the best bargin for cheap simple mods! I love'm!
Selling the parts? Selling the car?
$500. I'll buy it!
Coming soon:
slacker
