You Need To Do THis
SN95_DropTop
Well guys today i cleaned my maf and throttle body boy did that wake my car back up :santa_evil: . The car was running like crap. I couldent even keep up with my vert when i was running with my pops. If you havent done this you should do this it could help. Thats all I thought i would let you guys know how happy i am time to go waste some gas lol.. 8)
Robuilt
McAllen, Texas, United States
do you mind elaborating on how and what you used to clean it.
i WAS gonna do it today but got caught up on the Cowboy game. I bought some throttle body cleaner. Did you use the same stuff for both the MAF and TB?
just wanted to ask since i will probably be doing this tomorrow night
2slo95fiveoh
Lawrence, Kansas
there is a special cleaner specifically for mass air sensors. throttle body cleaner is too strong for the M.A.S.
at most auto parts stores, in their house brand you should be able to pick up a small aerosol can of TB cleaner and
another can of Mass Air Cleaner for less than 8 bucks. just take out your intake piping, spray the little silver sensor inside the
Mass Air housing, and open up the throttle body and spray the crap out of that.
Nacho
not saying he was mistaken, i'm just saying that I've never had a problem.
95PGTTech
2slo95fiveoh said:
i was told by a fellow tech. at work not to use TB cleaner on M.A.S, but maybe he was mistaken. :santa_undecided:
he is correct. and you should not be using brake/carb clean on a tb.
SN95_DropTop
Well first i disconected negative cable off battery then I took off the maf then got a Cutip cleaned it with some electrical cleaner i then took the throttle body used some thorttle body cleaner from STP then i cleaned the IAC put evrything back together started it up let it run about 2 or 3 minutes but watch out it will try to to stall at first but then everything was good got my power back because before when i used to wot it would fall on its face.
here is a site that helped me understand things
http://www.muscularmustangs.com/iac.php
