im gunna throw up.....
MustangChris said:whats a PCM harness?
whats the cooling mod, does 04 come with it stock, and how much does it cost? lol.
Shame302 said:Don't take this the wrong way man but you are getting in over your head. Take some time and really research this, Otherwise you are going to make an already very expensive swap un necessarily more expensive. I can't believe your paying a shop to do the work. There is no reason you can't do it yourself. I can only imagine how much they are going to charge you for their time/work. That would be incentive alone to DIY.
You said the engine is still in the cobra? Where is the car? Is it a wreck? The more you can get from a single donor car, the better.
KWClutch said:x2 to what that guy said about the donor car.
J.R. said:MustangChris said:whats a PCM harness?
The PCM harness is just another way to say ECU, or ECM harness.
The cooling mod, taps a hole in the back of the driver's side head, and let's the coolant circulate fully through the motor instead of pooling in the back and causing a bad valve guide or lifted head.
There's several way's to do the swap. Give me a call tonight and we can go over your options before you throw a pile of cash at it.
You can do as suggested, and basically make your car a Terminator in SN skin, or you can swap to a return style system, keep your coil packs, and everything else stock and only swap engines, give me a call tonight Chris.
No it's not. If you have the ability to swap the engine in, you should be able to do the entire swap yourself and save a ton of money. If you get everything you need you should be able to get this thing done "turn key".I'll be doing the motor swap, but the fuel and electrical is way beyond me...
There are 2 versions of the mod. I chose the LDC version. You can do it and its very easy. Pop out the plug in the back of the drivers side head and install the fitting and replace the passenger side fitting with the supplied one. Done. This is the one i used.is the cooling mod something that i can do?
Shame302 said:No it's not. If you have the ability to swap the engine in, you should be able to do the entire swap yourself and save a ton of money. If you get everything you need you should be able to get this thing done "turn key".I'll be doing the motor swap, but the fuel and electrical is way beyond me...
You need to have a good understanding of what's going on and all the parts you need before you buy anything (aside from the engine).
Are the 96-98 cars returnless? If so, stay returnless. No need to change over to return style.
http://www.svtperformance.com/forums/terminator-talk-229/487018-terminator-custom-head-cooling-mod.html
Here are the 2 different kit styles.
http://www.socalterminators.com/ldc/index.html
KWClutch said:Yeah but if you can get the donor car parts cheap do that and just swap it all. It was designed that way. I want to eventually go back to return style but you'll need to upgrade your lines, buy an aftermarket fuel pressure regulator, Aeromotive fuel sender to send the extra back. And upgraded pumps because you'll burn up the cobra pumps. They weren't made to run all the time.
Not true.i cant do "turn key" because of the PATS.
KWClutch said:Not sure what they did to fix it but it is fixed in the 04 heads. Some people try to sell 03 heads as 04. 04 Heads have blue paint.
Shame302 said:Not true.i cant do "turn key" because of the PATS.
Get the gauge cluster, ecm/ecu (computer), key, key cylinder, pats module (Its a tiny green connector just above the key cyl on the column) all from the same car and that **** will fire right up.
The engine, wire harness etc can be pieced together from other cars.
The only difficult part of the swap will be dealing with the dash harness differences between the 2 cars.
You should be able to for the most part. You have to in order to use the terminator cluster anyway.i cant just pull my OEM dash harness and put in the terminator dash harness?
