1996 SVT Cobra Father and Son Build
apsmith49921
I guess my point here is many guys go with the centrifugal setups due to them being affordable, easy to install and reliable. But yes you can go out and spend 2 grand for a questionable turbo kit
Just an option for the OP lol if he wanted to go turbo that's got pretty much all he needs minus the k member and tuning
evilcw311
Most Evil Member!
Louisville, KY
I wish I’d only have $2k in my turbo kit. [emoji38]
My hotside alone is half of that. My coldside will be more than half of that. My turbo alone will be about double that.
Venompower
Batavia, IL
Turbo’d are great because even if you lock up a turbo you can still drive home, blow a coupler and still drive home. Superchargers depending on the type of you throw a belt your stuck.Sent from my iPhone using Tapatalk
For Procharger at least you can keep a stock belt and breaker bar in the car, if the belt shreds you can by-pass the Procharger with the stock belt and routing and still drive home.
Musturd
I went Vortech v3 on mine found it for 2500 and the head unit was new . Came with a Anderson power pipe as well can’t go wrong with a Vortech . Simple and effective
EdgarR213
