1999 Transmission work in my 1995?
1995V6
Hey everyone,
I am new to the site, and here for some answers. :thumbsup:
I have a 1995 V6 auto, and found a 1999 manual transmission. I am about to buy, but doing some searching first. I am getting everything, clutch, pedals, trans, flywheel etc.
From what I understand their are a few things possibly standing in my way. The speedo, tail shaft and possibly the drive shaft. First the speedo, is there anyway I can covert to the 1999s electronic speedo to my 1995? And do I have to swap the tailshaft/ drive shaft to work on my year?
Any help, write up or incite will help. Really want this to work, but want to have a game plan first.
Please SCHOOL ME!
Thanks!
-95V6
1995V6
Thanks I was just about to register over at 3.8 now and ask as well.
1995V6
atlanticblue98 said:
ca-ching!
http://www.v6power.net/vb/showthread.php?t=31989
if i recall correctly, you could use a Dallas Extended Range Speedcal to convert the 99-04 speedo signal to the 94-98. but i havent read about that in a long time. this would eliminate the need to swap tailshafts
Thanks, I will have to take my time and read over the whole thread. Really mad all the pictures are red x's, just me or is that showing up for you too?
Thats the kind of step by step write up I need/want!
atlanticblue98
ca-ching!
they are red x's.
1995V6
I need to find that with pictures, thanks for the post!
Has anyone on here done this swap that can help me?
atlanticblue98
unfortunantly, not many V6 guys are here. i had an Auto, so i cant be much of help there.
i saw your thread on 3.8, the guy who wrote the article on V6power.net is a moderator on 3.8 as well. i'd send him a pm, i havent seen him post in months
1995V6
Thanks for your help, hopefully 3.8 forum can help me out even more.
I appreciate your help!
P51CrazyHorse
I did kind of the opposite... I put a '94 manual in my '98 auto car. The only major thing I had to change was to wire in the backup-light plug for the new manual transmission, and jumper a couple of wires on the automatic transmission wiring harness.
Also, you will want to get your computer re-flashed to read for a manual (or replace with a computer from a stick-car), otherwise it does some ... odd... things.
atlanticblue98
1995V6, i didnt realize your original trans was an Auto, the auto tailshaft wont work on the 99-04 manual. you'd have to get a 94-98 manual tailshaft
you coulda just used a manual trans harness and have it plug and play.
1995V6
Thanks guys. The seller wants to know what I want to do.
So, to recap. Out of the wreaked 99 I need......
I think I can do this, but I do not have a good feeling finding a tailshaft out of a 94-98 manual.
atlanticblue98
out of the 99.
transmission
clutch/brake pedal assembly
driveshaft.
shifter
clutch kit
flywheel
and get some type of Handheld tuner to get the PCM to act as a manual trans car.
P51CrazyHorse
I would've done that if I could have found a '96+ harness. The one in the '94 manual was different enough to not work.
atlanticblue98
ah, then OP, you will need a 95 trans harness or splice in the wiring to your existing auto harness
