351W heads on a 302 Block
Win
Kennesaw, Ga
Has anyone done it???? I am just trying to think of some different options for a low budget build. If anyone has done it what kinda issues or any if that did you run into? Positive or Negative Comments post them up.
Edit : I know this isn't in the 94-95 Specific section i was just hoping to get a view from anyone that may have done this.
Paul
The threads at the bottom of this page will provide some useful information. Also do a quick search on the topic.
Long story short, old Windsor heads aren't going to be much/any better than E7TE heads.
modo
Philadelphia, PA
back in the day before kpi (lets see how many old times remember that name) people had good luck with cleaned up D0OE heads but they flow about the same as good gt40 heads. your best bet is to find a decent used set of aluminum heads but before you buy them i would recommend getting them checked by a machinist and cc'd if you can.
W
Win
Kennesaw, Ga
I saw people said they could be used but i was looking for actual results....
I have been doing a lot of research in the past 3 hours and i'll just stick with a set of GT40's
