5.0 build advise
Farr94gt
im currently building a 94 gt and i was wondering if anyone has used trickflows twisted wedge top end kits. thinking about going the street burner route cause 350hp and 370ftlbs dont sound to bad. any thoughts or direction would be helpful. thanks
Musturd
It's a great kit I'd run the stage 2 cam with it tho.
rollin315s
Don't believe the numbers they post with those kits. Your only going to see at most 330rwhp out of a h/c/i swap. A lot of the times you can get more out of it if you piece your own kit together.
ivan12
That's rated at the flywheel, with a good tune most see about 300 at the wheels. I have the track heat setup on mine running the stage 1 cam and a Procharger. Barely working out the kinks, startup should hopefully happen this Friday. You might be able to squeeze out a bit more hp out of a different setup but it might be hit or miss. The reason I went with the TFS kit was that it takes the guesswork out of the equation, which helps a lot if you're not an expert.
itsblue95
Louisville Kentucky
if i were you id put together your own setup. corral is your friend dont be affraid of buying used stuff. i bought most of my stuff new except a few things from a friend. corral has alot of great deals on there and i wouldnt be affraid of buying anything used from there. good luck hopefully you get what your looking for!
Paul
I'd take that money and buy a supercharger kit instead. You'll get more horsepower and drivability than the heads/cam/intake, plus it's MUCH easier to install.
I have the trick flow top end kit on the 306 in my '89 notch.
Paul.
BlkoutGT
MO
If I were to do it all over again... No joke, I would have saved up the money, bought a b&g turbo kit and slapped it on my stock motor. It would have been done a long time ago, still driving the car and building a bigger better motor on a stand in the garage. A vortech kit would be even cheaper and a easier install.
P.S. Not to thread jack but, Paul- Is that thing running yet? lol
Paul
It's not running yet. The sound deadening project is ridiculously long. All the Damplifier is in it. Now I'm working on the Luxury Liner Pro.
I'm retarded for doing this much work.
Paul.
blacknotch302
Paul how much hp do u think ur gonna be pushing just wondering cause I'm gonna have almost the same setup
Slykin
Tyler, Texas
I know this is kind of a retarded question to ask.. but what kind of MPG can you expect out of a SC vs mild H/C/I such as the track heat setup? I'd like to get some more power out of this pig of a car, but I still want to be able to drive it everyday, and on long trips a lot.
ajwhite4291
MD.
I have a 95 GT and have recently installed a DSS 331 Stroker with a TFS Track Heat Top End Kit with a Stage 2 cam. It made 354.5rwhp and 370ftlbs on the dyno. I can't tell you what MPG i am getting with it I have not drove it that much yet.
Paul
With a TFS top end kit on a 9:1 CR 306, and electric water pump and fan, I'm predicting 271 rwhp through a Tremec 3550. Some day when it's running and I get it dyno'd we'll find out if I'm right.
Paul.
Paul
I doubt very much it will be that much, but I'm also one hell of a glass-half-empty kind of guy when it comes to cars.
Paul.
F
Farr94gt
i thought about that route, i need to rebuild the motor cause it have 150k on it.....if i go supercharger, what kind of things should i change to the stock motor?
Paul
150k miles doesn't mean the motor is shot. Do a simple compression test - if the cylinders are all withing about 15 psi of eachother, call it good and put a blower on it.
As for what you could do - select a supercharger that you like, buy a new 255 lph fuel pump and perhaps an inline pump, some 42lb injectors, a Lightning MAF, and an Anderson Power Pipe and you're golden. Then get a tune. The motor itself doesn't need any mods. This is a tried-and-true combination that's been going for a couple of decades.
People love to over-complicate crap.
Paul.
