5.4 ?????
atrainsgt
It could just be the synchros going out in my trans, I wont know for sure until I tear into it. I guess it would be a good time to convert it to an auto tranny sense I hear its a stronger and it will be quicker in a straight line. I will look into that a little more and see what I'm looking at for the cost of that. I really wanted that t-56 but I'm not prepared to put that much cash into this car so I guess it will either be another t-45 or an auto trans. I have another project car I've been working on as well so the extra cash is running thin.
Jrgunn5150
Auto or TKO/T56, don't bother trying to beef the T45, that was an expensive road for me.
atrainsgt
I'm going to miss my 5-speed if I go that route but its looking like the smarter way to go. I'm going to look into a C4, never paid that much attention until now. I looked at the specs of that and I think its not needed for my application. So I guess I will go with a 4r70w unless the swap from 5-speed to auto involves more than I think. Time for a new thread :nonono:
Jrgunn5150
C4's are cheap and easy top build tough, but no overdrive makes for a sad street/strip guy.
voidfinger
thats why i said hard core lol. my dads fox has a c4 in there with 3.73's and it gets around 17 mpg when cruising.
Jrgunn5150
It'll probably cost almost as much to get an auto swap as it will to get a TKO though, even though the auto is stronger than that too :thumb:
atrainsgt
I can get a low mileage 4r70w for around $400, I should be able to round up the parts needed for the swap for less than $500. Still cheaper than a TKO.
Jrgunn5150
You could find someone who want's to swap and do it for free too :coolsmiley:
voidfinger
what kinda problems...? and i got my 4r for like 800 with only like 20k on it.... wonder what is wrong for the 400... never seen them that cheap without problems.
atrainsgt
Nothing is wrong with the 4r70w, its called connections :coolsmiley: no really
atrainsgt
I think I might have found out why that 4r70w is cheap, its out of ('03 f150 2 wheel drive) does that matter? I'm not sure if it comes with the stock torque converter or not.
Jrgunn5150
Doesn't matter, unless it had a 5.4, then it's stronger.
You'll have to re-do some wiring inside, but nothing major.
atrainsgt
Oh yeah, my car is 1998! What does that screw up as far as the tranny setup goes? About the wiring, is there a diagram somewhere so I know what I'm changing?
Jrgunn5150
It's just the arrangement of the pins on the shift solenoids. I can walk you through that easily enough, you'll need the correct VSS for a 98 also.
atrainsgt
Could I just give you a call when I get the tranny? That would be a help. I'm going to try and pick it up this weekend.
Jrgunn5150
No problem, or hit me on AIM, yahoo, whatever is easiest for you. i just don't want to type it all out if you decide not to go through with it, lol. Was it a 5.4 trans?
atrainsgt
I added you on yahoo and AIM, I won't bug you with it until I know I have it for sure. I had found a couple more transmissions since my last post I will spec them out for you.
2001 f150 5.4L(58,000 miles)= $588
2003 f150 4.6L(23,000 miles)= $600
I figured the 1 with the less miles would be a better choice, how long are these 4r70w's lasting before they start acting up?
RevJon
