94 Mustang Build Thread UPDATED 3/20/11
94Pro-5.0
94Pro-5.0
Little Elm, TX
Re: 94 Mustang Build Thread UPDATED 7/29/10
blackpony said:
thats a super clean car you have there!!! what it the cr on your engine? i am building a similar setup, but with a few more cubes and a different exhaust, and am hoping for 430 ish to the ground.. i see that you made 341 and 321....
my cr is only about 9.5. i plan to boost. you wont see over 400hp unless you have a custom cam, some badass heads and a really good tune. 430 is a big goal.
onlyme said:
Awesome car, how did you shave the reflectors in the bumper though?
i cut out the housing for the reflector from the backside of the bumper, feathered the edges, used a 2 part liquid urethane filler with rubber mesh for strength. then finished it off with a flexible filler and thats it. took a LOT of sanding, and sanding rubber sucks
94Pro-5.0
94Pro-5.0
Little Elm, TX
currently in the works:
Vortec V2 S-Trim
reverse dome pistons
Victor jr. 210cc 2.05/1.60 heads
MSD pro-billet
Bassani 1 3/4" shorties
stainless x-pipe
Magnaflow Magnapack catback
canton overflow tank
polished alternator, Power steering pulley, idler pulley and tensioner pulley
chrome timing cover
12" JL Audio W6
7" screen
i'm also finally painting my hood and building a custom spare tire sub enclosure.
94Pro-5.0
94Pro-5.0
Little Elm, TX
finally starting to get all of the parts i need together. now i'm just waiting on my backordered probe pistons and total seal rings. they told me to expect them between january 6 - 16th.
94Pro-5.0
94Pro-5.0
Little Elm, TX
Pistons came in early! just waiting for the rings now
probe pistons and new vortech brackets and hardware
94Pro-5.0
94Pro-5.0
Little Elm, TX
Today i mocked the supercharger and pulleys on the motor. i also had some holes welded up on my edelbrock elbow. Now i need to make a custom discharge tune from the SC to the TB. I also need to chrome or powder coat my crank and water pump pulley, as well as the new supercharger brackets.
I also found out that my polished Wazee tensioner pulley is almost exactly the same as the ugly plastic Vortech idler pulley. Vortech makes a replacement for the plastic pulley in billet aluminum, but they want $140. I can get the Wazee pulley and make it work for less than $50.
Heres some pics of the mock-up. not very pretty yet. Still need to polish the blower
blackpony
dang man, wish i would have known you were looking for a set of pistons. i have those exact pistons that i will not be using for my new build.. only have about 200 miles on them.. good luck with it!!! should run good!!!
blackpony
hey man your inbox is full.. and sorry i took a second look, and mine are the -13.8cc .030 overbore pistons part number 10662-030, not the -14.2cc std bore. but would like to get around $250 plus the ride for them...
94Pro-5.0
94Pro-5.0
Little Elm, TX
some small updates on the new motor
everything is at the machine shop getting balanced, so in the meantime i'm getting everything ready to powder coat.
welded up 2 holes in the intake elbow
started polishing the blower
and i've always hated how the coil is mounted, so i'm changing it up a bit. this is just a mock up on another bracket i had. i wanted to make sure it worked before cutting up my nice bracket
i'm also about to order my ed curtis FTI custom cam
94Pro-5.0
94Pro-5.0
Little Elm, TX
used 150 grit with a DA, then by hand i used 400, 600, then 1000. The polish i used is a home made polish i bought at a car show probably 5 years ago. it works great.
i might spend another hour on it, jump up to 1500 grit to make it look like chrome, but i think it looks pretty good as it is.
Unless it's a show only car, that seems bling enough for a driven car.
Looks great.
94Pro-5.0
94Pro-5.0
Little Elm, TX
Win said:
Which V do you have?
its a V2 STrim
Looks great.
i'm going for a little bit of show and go
i'm about to buy another vehicle, hopefully a harley f-150, so this wont have to be driven everyday when its finished
Jerry santos
