95 GT auto performance??
cam/fast
just purchased a 95 GT automatic.....what mods should i begin with??
car is fully loaded and its great....but it runs like a pig!!
is the AOD any good?? What can i doo to make it perform better without spending big bills??
im looking at a turbo kit and leaving the motor stock (8-10psi) (upgrade block and h/c/i later)
what kind of performance should i expect??
thanks..HD
AaRoN
King Post Whore
Don't wanna spend big bills but you're looking at a turbo kit :hammer:
Gears, H/C/I
First things first though: Normal maintenance. Make sure everything is updated and cleaned.
ga94gt
Before I did any of that install a shift kit, trans cooler and gears. The trans is the weak link. The gears to help you off the line with the auto and maybe even a stall too.Do the weak link first.
C
cam/fast
Gears, H/C/I
well....a turbo kit would be around $3500...but first i would have to make sure the engine and tranny are ok for boost....
i guess it would be a better bang for the buck than h/c/i and i wouldnt have to tear my motor apart...plus i can leave stock gear ratio :hammer:
AaRoN
King Post Whore
cam/fast said:
Gears, H/C/I
Yup. Does the kit come with all the neccesary supporting mods?
C
cam/fast
the transmission shift perfectly but....trans cooler and shift kit sounds like a good idea to get it ready for any performance upgrades
i dont want to push it too far either...mild boost...then ill upgrade the trans for more power
C
cam/fast
i have 42lb injectors..walbro 255..t-rex in line..and c&l 80mm meter
dont have the throttle body (upgrade later) and i would have to get it tuned..
had a coupe with a vortech..so it should be good to go
LAFENATU
A turbo will grenade your stock converter.
Normally I recommend building a car from back to front. You have an auto so unless you plan on using a brake....stock axles should be fine.
Get a self regulating trans cooler, Long makes a great one. That should be #1 on your list, period. Heat is the #1 cause of trans damage.
Your stub shaft/input shaft on your AODE is a weak link. It is known to twist with a power adder. A 1998 or newer AODE/4R70W Stub/input shaft is hardened and is a great modification.
You will need a converter. Need to get one with Anti-Balooning plates that is made for power.
A shift kit is a great modification also, quicker shifts = less heat. Less heat = less chance of trans damage.
AODE/4R70W internals are pretty decent otherwise. That trans is miles ahead of the original AOD.
-R
C
cam/fast
-R
Definately.... upgrading the internals is what im looking to do....as a matter of fact Circle D transmissions is around the corner
from my house (in Houston) and they do many performance upgrades on AODE...
i really appreciate the information you listed :thumb:
