Abs light and humming
9838stang
Minneapolis,MN
Well peeps, spoke to soon :angry:
Lastnight I attempted to go out and get some cool night shots but the car had other plans. I started out for an hour looking for a spot but nothing looked good. So I went home while taking off from a light and a smooth pace. I saw my abs light came on. I pulled over to check the rear abs sensors since they don't sit completely flush against he mounting surface of the rear axle. But they wasn't any play. I had the car off and heard a humming sound and figured it was something with the ac so I kept going home to further check it out. I get home. And I pop the hood. It sounds like the ac compressor was still letting off pressure but it sat for 5 minutes and was still the same sound. I went into the car and heard the same hum. So I touched the abs module and it was hot! I don't remember doing any heavy braking at all.
I disconnected the battery of course the hum went away. Reconnected battery hum came back. Undid the plug to abs module, hum went away plugged it back in hum came back. Pulled fuse 29 under dash, hum still was there.
Dunno what to check else sounds like a bad abs module
How does the module operate? Is it set up to come on with certain voltage or pressure or what? If its voltage operated you could check the voltage at the plug with a multimeter, or check the plug for a short to ground. You did just do a lot of wiring and it could have chaffed a wire making the pump run all the time.
I put the same post in you build thread
9838stang
9838stang
Minneapolis,MN
To be honest with you I'm not sure. I would like to think that the system is a voltage operated just because there is two leads running to eat wheel and have a magnet attached to it that senses when the ABS ring is going around. But at the same time I know that I have hydroboost now so I don't know if there is no pressure or what I guess I gotta figure that out
9838stang
9838stang
Minneapolis,MN
g36 monkey
Orlando, Fl
HID's could have caused it to freak out. Not an uncommon issue for our cars
g36 monkey
Orlando, Fl
?What?
I dont understand how this makes sense at all?
The ABS Gods just hate HIDS. That's what we have come to terms with in the Mustang community. So we just leave it at that lol
I dont have those anymore. Gave those up 2 years ago
I thought so but I could have sworn I read something in the OP about a ballast or whatever lol. My bad dude :)
9838stang
9838stang
Minneapolis,MN
It is all good brosif lol
EdgarR213
