Best way to remove the nipple off our Headlights ?
Duff Daddy said:
Originally when they were made, the lenses had a "box" that was used for alignments, some shops still use them. It is or alignment purposes but now an easy way to align headlights is to measure with a meter stick, to the center of the head light, then 15 ft in front the same height and cross width and your golden on a board.
this is your "mystery" tool
duffy, can you explain that? im replacing my headlights and will have to re align them... you way sounds much more accurate than "wingin' it."
i didnt understand the process...
W
Win
Kennesaw, Ga
Chris you can also align it up against a Garage. I did mine inside my garage, but you can just as easily do it on a garage or wall just make sure your car is level.
thats what i did this first go around... ... turned out okay... but if there is a better way to do it... im all for trying it!
man I totally forgot.
My granddaughter was here when I got home then I had to make dinner.
I'll get them though... really
P51CrazyHorse
Use a torch. Melt them off. Will be smoother when finished than if you cut or grind them, so less sanding/polishing!
A lightsaber would work too, but good luck finding one of THOSE for a reasonable price these days...
W
Win
Kennesaw, Ga
I don't think you could regulate the temperature around the area enough to not cause a odd shaped melted spot.
P51CrazyHorse
Is ... is that the *only* reason you don't want to try it?
ARdoller
-Never Forget-
is that not enough of a reason to not do it?
5litrarag
A friend of mine used a dremel and cutoff wheel to take the nibs off his headlights and then sanded the rest of the surface and it came out great. No pics though... I'll be doing mine pretty soon and I'll get some pics.
