Hey guys, it started as a 1995 GTS that I bought 3/31/2005 (weird that I remember that date off the top of my head). Here is what I have done to the car that I can remember off the top of my head:
Exterior
Cobra front bumper
Cervini’s 3.5†hood
APC black projector headlight
XtraXenon 7000k HIDs
New LF fender
Rear wheel well lips rolled
OEM GT spoiler
Painted mirror
Whole car painted w/ STANDOX single stage (I hate it)
’95 Cobra R wheels w/ Nitto rubber
“302†fender badges
Custom painted pony emblem
Interior
Retrofitted power windows and door locks w/ alarm system & door panels
FR500 Steering wheel (column painted to match for now)
Alpine radio w/iPod cable
2000 OEM Cobra R seats (actual originals, not the Ford racing ones)
Kenny Brown Super Street cage
A1 Auto replacement carpet
GT cloth rear seat
Auto meter gauges & shift light
White face gauges w/ red painted needles
Ford racing shift knob
99-04 e-brake handle & boot
Ford racing pedals
03/04 cobra gas pedal recall plate
Simpson 5 point harnesses
Agent 47 seat belt guides for roll bar
Engine
DSS built 347 Big Bore, 8.8:1 CR
Dart Iron Eagle block 4.125†bore
DSS Forged 331 stroker crank
DSS Forged H-beam rods
DSS custom CNC made pistons
DSS custom pushrods
Comp hydraulic roller lifters
FTI (Ed Curtis) custom cam (0.605â€Â/0.600†valve lift
AFR 205cc CNC ported heads
Comp Springs, Teflon valve seals
Cometic head gaskets
Scorpion 1.6 roller rockers
Trick flow valve covers
Edelbrock Performer RPM II
Edelbrock 75mm TB
MSD Pro billet distributor
Canton 7qt pan
HP Performance 66mm stage 2 turbo system
Tial 44mm wastegate
Billet bosch style bypass valve
Siemens 60lb injectors
SCT BA2400 MAF
MSD 6AL
MSD coil
Taylor spark plug wires
Autolite XP3923 plugs
ROMAC 28oz. balancer
Modified March alternator bracket
Moroso breathers w/custom vacuum pump system
Twin Pierburg 255lph fuel pumps
3.8L Taurus fan
3 core aluminum radiator
DC Control fan controller
Ford racing water pump
SLP Loudmouth II exhaust
Energy poly mounts
Mcleod Twin-disc clutch
Mcleod SFI bellhousing
Driveshaft loop
Tremec TKO-600 trans
Strange custom 3†driveshaft
Moser 9†rear end 3.50 ratio, widened ¾†each side
Steeda Tri-ax shifter
MGW shifter handle
Front Suspension
Energy poly bushings & isolators
Bilstein HD struts
MM caster/camber plates
’95 Cobra R Eibach springs
Eibach sway bar
’00 Cobra R tie rod ends
MM steering rack bushings
’00 Cobra R Brembo brakes w/hawk pads & slotted rotors, braided hoses
Quantum motorsports brake duct kit
MM steering shaft
Rear suspension
Evolution Motorsports Tri-link (modified to fit 9†housing)
MM adjustable LCAs w/spherical bushing
MM Torque arm springs (H&R)
Eibach sway bar
Cobra rear disc setup with slotted rotors and hawk pads, braided hoses
Bilstein HD shocks
MM Panhard bar
Chassis
Edelbrock strut tower brace
Steeda full length subframe connectors
Kenny brown jacking rails
UMI upper and lower torque box reinforcements
Custom front and rear tow hooks
Street tires: Nitto NT555RII’s 275/40-17 front/ NT555R’s 315/35-17 rear
Road race: Nitto NT-01 275/40-17 front & rear
Drag race: Hoosier Drag Radial 335/35-17 rear
And of course, some pics (they go in chronological order if that helps):
Kurgan sent me a base tune via UPS just to get the car running and mobile. Well I drove it for like 2 or 3 days and I had the wastegate hooked up wrong. 23+ psi blew the stock head gasket on the #4 cylinder. Time for a new motor:
That's me on the left
Moderate timing, 93 octane, 13psi boost, fucked up boost controller, 2 burned plug wires, misc issues
Exterior
Cobra front bumper
Cervini’s 3.5†hood
New LF fender
OEM GT spoiler
Painted mirror
“302†fender badges
Interior
GT cloth rear seat
Ford racing pedals
Engine
DSS custom pushrods
Edelbrock 75mm TB
Canton 7qt pan
Tial 44mm wastegate
SCT BA2400 MAF
MSD 6AL
MSD coil
3.8L Taurus fan
Energy poly mounts
Driveshaft loop
MGW shifter handle
Front Suspension
Bilstein HD struts
Eibach sway bar
MM steering shaft
Rear suspension
Eibach sway bar
Bilstein HD shocks
MM Panhard bar
Chassis
