botls vs studs
I am getting everything together now to put the motor together and from what I have heard its better to use studs over bolts when you can? I would like to use studs on the intake but I cant' seem to find any that have a 1/2 - 3/8" longer to allow for the spacer I need to allow for my heads. Anyone know if they make them and where to get them?
ElrodKTPQ_89
Crossett, AR
I've heard of people just using all thread for the intake if they can't find long enough bolts. Just take a measurement on length and cut it and use lock washers and nuts.
I am actually replacing a piece of all thread and was just hoping to do it right this time. I sent an email to arp last night hopefully I will get a good anser back.
ElrodKTPQ_89
Crossett, AR
That's surprising. I just happened to get lucky when I swapped intakes and found the right length bolts for the two middle holes in the cobra upper. If I had been using any size spacer then I would be exactly where you are now.
1bad95
I used all thread on mine on my 95 with no problems
Sent from my XT1080 using Tapatalk
I had a piece of threaded rod in there when I took it out but with the vortech going on it I was hoping to replace/upgrade every bolt on the top end. I already have a arp head bolt kit, and I am pretty sure they make a lower intake stud kit and just hoped the upper had something to go with. Anyone know if you can piecemeal the studs together if I have the lengths of them all?
threaded rod/all thread/ready rod I am pretty sure is all the same thing just a threaded rod from one end to the other. While it works the same as a stud I can't help but think not being heat treated and such that it can't be as strong.
95opal
You dont need anything special for the upper as its only torqued to 18-24ftlbs. ARP will have the lowers but uppers are nothing special. If your worried grade 8 studs can be sourced just about anywhere
not in the crappy little town I live in I end up ordering more little/simple crap then I would like too.
Markstang73
