brake light coming on?
98_MustangGT
my e brake light is coming on almost everytime i apply the brakes now. does anyone know why? would low brake fluid cause this or do i need new brake pads?
94darkhorse
Idawahio
Happens in my 'Yota from a brake fluid leak. You might want to start there.
G
GREG@SN95
if its the ABS light... then you wheel speed sensors are dirty.
Check your fluid level and pads... It could also be the switch for the parking brake...
realitygt
most likely needs brake fluid or ur brake pads are needing replaced soon
same thing happened to me a few weeks ago.
916_5.0
Add some brake fluid mine did the same thing when mine was low. I put some in and problem solved.
