cali smog question
95gtdrop
sacramento
so i was going to pick the h- pipe up today and dude flaked on me. aint that a bitch!!! cant drive the stang until i get it smogged. registration was up in june. my poor baby is in the garage collecting dust and im stuck driving my 4x4 yota everyday!!!
CC'S95GT
Hampton ,Ga.
Yea 5.0
wow I really spaced. I was reading fortysix or fifty not 4.6 or 5.0.
the OP has a 95 so he has a 5.0
95gtdrop
sacramento
does anyone have experience with catco cats?
found a guy with a stock h pipe but the rear cats were replaced with catco. he said it passed smog with and ecam and gt40's.
cmsismyname
whatever cats you get make sure they are odb2 cats or else it still wont pass smog in cali. Not all cats will pass california smog it
must be obd2
95gtdrop
sacramento
yeah obd1. got my stock hpipe the other day. brand new catco cats and the 2 stockers up front.80 bucks. too bad my garage door broke so i cant get my car out to get it up on the ramps or jack stands. FML
95gtdrop
sacramento
so i changed out the bassani x for the stock h pipe, timed it to 10*(factory) drove the hell out of it before i took her in, changed the plugs, and my readings were still way to high. the guy said it was borderline gross poluter. i cant figure out what the fuck is going on. any ideas? im about to remove my cobra upper/lower and put every stock part back on and sell this bitch. and get something else. why all of a sudden would my readings be sky high?
95gtdrop
sacramento
yeah the bassani has two cats, one on each side (2), where as the stock h pipe has two on each side(4) i figured since i had 2 more cats over the last time i got my car smogged id be good to go.
MadStang
Escondido, Ca
oh I read that backwards I thought you put the x pipe on in replacement of the h. what were the results? what was the high number? NOx?
95gtdrop
sacramento
so im putting my stock upper lower intake back on, stock throttle body, and putting everything back to stock hoping it will pass. would a 70 mm throttle body and a ported cobra intake produce higher emmissions on a stock motor?
im getting very puzzled.
i had an oil seperator between the pcv and the intake and he failed it visually because of that, and i had a "t" fitting in the vacuum line for a vacuum gauge. this guy was a prick!
