Codee's 2kgt build UPDATE 07/07
Cpotts13
Biloxi, MS
Hello, my name is Codee and this is the story of my Mustang.
I purchased it used in May of 2011. When i bought it it was BONE STOCK aside from a drop in K&N filter.
Here is a list of mods that I have done (In blue) and what I want to do (in red)
Performance:
-MAC off road H pipe
-MAC catback
-Airaide CAI
-profesional products 75 mm tb
-profesional products plenum
-Bama tune
-underdrive pulleys
-vortech v1 non inter cooled supercharger
-302 stroker, big cam, teskid block. N/A beast. (dream)
Drivetrain:
-Frpp 3.73 gears
-mgw short shifter
-new oem drive shaft
-spec stage 2 clutch
-spec aluminum flywheel
-aluminum ds
-built rear end
Suspension:
-H&R super sports
-tokico shocks and struts (blues)
-J&M lcas
-eibach anti roll kit
-mm cc plates
-poly isolators
-cobra brake calipers
-bear eradispeed 2 piece drilled and slotted rotors
-ss lines
-nittos up front sumis out back
-bilstein shocks and struts
-bumpsteer kit
-steeda x2's
Asthetics:
-deep dish anthracite bullitt rims
-tinted windows
-oe replacement taillights
-led 3rd brake light
-OE smoked headlights
-cowl hood
-99/01 cobra bumper
-pearl white paint job
Maintenance:
-edelbrock water pump
-pa perfomance alternator
-ngk platinum spark plugs (.054 gap)
-pi intake manifold with aluminum cross over
This is the day I broght her home.
Completely bone stock with 85k on the clock
The first thing that had to go was the oem shocks and struts, i was bouncing down the road pretty badly.
Had a american muscle brand shift, it wasnt to good...
Out with that and in with the mgw. Also installed the mac o/r h and catback at this time, but no pictures..
rims somewhere in between :0
Decided to paint the calipers and brackets (totally not worth the time..) Before..
after
Had to remove the dumb dealer sticker..
Clean
How it sits today.
JoshHooten
Hiram, GA
Looks good man it's really gonna look good once you get the springs on there.
I have ford c springs also
JoshHooten
Hiram, GA
I love them they ride almost like stock ,Very smoothe .
Mine are also cut I cut 3/4 a coil in the front with the stock iso's and in the rear I cut dead coil+1/4 coil without iso's and it still rides the same its a very good ride.
Unlike some other springs like the eibachs where people complain about them being to stiff .
I think you will like them.
C
Cpotts13
Biloxi, MS
I got them really because the drop wasnt to much, i didnt want to rub in the rear with 315's. did you notice a handling difference?
JoshHooten
Hiram, GA
Yes it handles much better.
I have 315 rears also I rolled my fenders and have some small spacers 3/16th i think with no rubbing issues but with the different body styles idk
how your body style would be . I have some pics of the clerance I have if you need them.
C
Cpotts13
Biloxi, MS
I dont think it will lower it enough to hit the fender, i am going to keep all the coils and isolators. If you can post pictures of the rolled fenders that would be cool, i havent actually seen "rolled fenders" before..
C
Cpotts13
Biloxi, MS
Springs are on hold. car decided to take a sh*t on me today. It idled at 2500 and wouldn't drop lower than 1500. I couldn't find anything wrong, so i dropped it off at the shop :(
C
Cpotts13
Biloxi, MS
Alot has happened since I lasted posted, the idle problem was solved by cleaning the throttle body and plenum with som carb cleaner and all new gaskets for everything..
Like i said, it completely solved all my idling problems.
Also had the time to install my lowering sptings and caster camber plates, took me and my friend about 5 hours at a slow pace.
And i will take a bit of pictures when i take it to get aligned later today!
Coltrain
good lookin car, im about to post a thread about my 02 GT i picked up a week ago, im ready to see pics of yours lowered now lol, took me and a buddy yesterday right at 2hrs to lower mine
C
Cpotts13
Biloxi, MS
I didnt use iso's on the front or the back and the front is smooth with no problems, but the rear "clunks" over bigger bumps, otherwise rides smooth. is there a fix to this? also will the springs settle more overtime?
C
Cpotts13
Biloxi, MS
Alright guys, heres a little update..
My next purchase:
-replace all lights on the car. there all either weather worn or leaking, ive tried to restore and seal them but its a no go..
- have the whole car retinted
Summer list:
-lca, the bushings on the stockers squeek like crazy
-cai + tune
-eibach sway bars
-big brake kit!! (lmr cobra kiit)
-audio
-racing seats + cage
Let me guys know what you think! and if you have any brand suggestions!!!
C
Cpotts13
Biloxi, MS
Alright, ordered a set of J&M lca's, and some polyurethane spring isolators. Ive realllll gotten sick of the squeaky bushings on the factory lcas and the "clunking" from installing lowering springs without isolators!!
JRad405
Central NJ
For the clunking check if the springs are seated properly. I had clunking on a different car and it was only because of that reason.
The car looks good. My car was bone stock when I got it with 85k on the clock too.
C
Cpotts13
Biloxi, MS
i will find out soon! haha. The parts should be in saturday.
JRad405
Central NJ
Sounds good. I run ISO's on my B springs (similar drop to C springs). Honestly I think it's worth it and I don't really notice much of a difference. Plus I live in pothole land.
