Coolant issue Help again..
TheNatster513
Alright i got my electrical problem fixed but now i have no coolant reading in my gauges. I know that the coolant is moving through the engine.
dont know if this helps but i put the thermostat in backwards.. its right now. lol. but i still have no gauge reading. i replaced the coolant sensor that is in the lower part of the intake. is there another one? could i have fried it with my alternator issues?
modo
Philadelphia, PA
take the wire off the sending unit and ground it. if the gauge pegs hot then the gauge / wire is fine and its the sending unit
toyman
It sounds like you replaced it before the alternator problem. To be clear, you are referring to the dash gauge sending unit on the driver's side intake, correct The ECT sensor is on the T-stat housing.
T
TheNatster513
ok. what? i need a dumby version of that.. i replaced the sensor in the black tube on the lower intake on the passenger side.
ivan12
There's another small sensor on the drivers side of the manifold. This is the sensor that gives you the temp reading. It should have a small 90 degree connector on top.
T
TheNatster513
the one thats not there on the gt40 intake? its really tiny almost looke like a small stud on the front of the intake?
T
TheNatster513
the little red circle in the top left of this pic?
Adam95GT
You put this... on it. It should be on the wiring on the lower intake i had to remove mine to extend it.
T
TheNatster513
Put it where?? There is a different sensor in the new intake. So do I put the old sensor in the new intake? It looks like it's a diff size
Adam95GT
Yep use the old sensor front on the drivers side is most accurate for temp readings.
Adam95GT
Im not sure if the threads are the same you will have to look at them. You just slip a deep socket over top of it... 15mmish IIRC.
