Door Lock Issues Please Diagnose
ram360
I have been having some issues w/ the door locks (94gt). Basically they both lock/unlock w/ the key just fine. Only the drivers side opens w/ the key fob. None of the doors lock w/ the key fob and the door lock switch inside the car will not lock or unlock the doors at all. I can hear a clicking come from the drivers side truck area when I push the buttons but nothing happens. Is there a relay back there? The trunk opens w/ the fob and key just fine though. I don't get it...I tested the fob at autozone and it functions normally. Obviously something in the car is fubar...ideas?
eliyarbrough
Nocona, TX
That kind of happened to to me last Xmas. My driv side work, but my pass side just quit. Mine was bad all of the time though! I don't like my family that much, so I sat out with my car for about 1-2 hrs. My lock would not raise up enough to even grab it good. I just kept unlocking & locking it @ the door switch. After doing this about 1000 times, it just started working. I'm almost positive this will not help you though. That's all I know though!
R
ram360
haha, thanks man. I was hoping to take a more technical approach than that. :hammer: Lock actuator got to be good since it works w/ the key fob, maybe bad lock switch causing both locks not to work?? I dunno :rant2:
95 svt cobra
does it unlock fine with just the key? they might just be gunked up a little bit. WD40 should clear that up if thats the case
R
ram360
they open perfectly fine w/ the key....the drivers side opens w/ the key fob but not w/ the buttons...wish I had an extra switch to swap in just to try....
