Eveyln's Resurrection
1998cobrasvt
Pshttt it'll never be done there's still the teksid swap and so on 4 valve goodness or stay 2 valve ? So many choices lol
:thumbsup:
Maybeee lol My dad does wiring on the side and programs for a living so i was just browsing threw the almighty electronics book thinking 555 timers or capacitors I'd like to have variable adjustability with the modules mounted in the car for more gangsterness
Maybe I like the DIY parts maybe because I'm hard headed and stubborn? Maybe the young part still plays lol
Big ups to that man!
Ineedav8
Ineedav8
South Florida
Well a new years resolution is to finish one of these millions of projects
1. Chop down rsx brackets
2. Install my part stash i have in my room (s.s. brakelines, motor mounts etc.
3. Fix the stupid speed cal!
4. Fix exhaust leaks and switch to Borla Ataks
5. Engine bay refresh
6. Way more stuff then i care to type
Ineedav8
Ineedav8
South Florida
Did other things then knock down my list already lol. Ordered a dash kit from Crutchfield for the horrendous double to single din kit *insert high school part time budget* hacked away at my dash swapped my shift boot over and ripped some rats nest out as well as the factory mach 460 amp I bypassed originally
Lovely ness
Better pics will come when i finish right now the radio is sitting in the bezel on top of a microfiber
Ineedav8
Ineedav8
South Florida
Well sad day.. throw out bearing is about to give out and me needing the car for school and work I'm babing the crap out of it any more 40 miles from home after kilts and cars and driving to Hollywood to meet some family the throw out bearing just starts squealing unbearably for a few seconds then goes away then comes back again
Ineedav8
Ineedav8
South Florida
$1,558 later in covered for another 6 months and just sent pay pal mula for some maximum motorsport goodies now to pull the whole drivetrain
Ineedav8
Ineedav8
South Florida
Welp doesnt even matter any more motors toast but the valve cover looks decent if only i didnt run low painting base and clear thought about an ls swap but have a teksid in the garage time will tell bank 1 was all 100 125 130 and 120 bank 2 was all low 60 and 90s so motors def got worn rings
Ineedav8
Ineedav8
South Florida
Caster chamber plates came in today from ttocs first time buying anything from anyone on here and couldn't be happier they cleaned up really well
Also plan on installing 24lb injectors on the teksid for shits and giggles now
Burninriverdiver
Sucks to hear about the engine compression, that's nice that you've got a teksid block sitting there to build tho. Just make it faster and stronger than the current state!
Ineedav8
Ineedav8
South Florida
Well threw my injectors in and started to piece togther the whole shabang parts needed are as followed
96/98 cobra rails
Navigator water pump
C heads for more low end
96/98 cobra cams
Gasket set
Bearings
Maybe 03/04 internals or Coyote rods etc.
Head cooling mod
Egr delete
Dowel upgrade
Billet oil pump gears
Canton oil pan
And just tons of gangsta powder coating.
Plan's to be ready for boost come next year but no promises
Plans to clean it top to bottom and tear down after i trade my seats for some paint guns
Ineedav8
Ineedav8
South Florida
Well I'm practically using this thread to dump all my pics lol but here's from yesterdays even tho the ccrm died again and made me late for work swapped one from a friend and fired right up. Also did a unusual color
Copper
Tested fr500
And i was way to excited and couldn't contain myself
Ineedav8
Ineedav8
South Florida
Started trying to hunt for 03/04 cobra internals i will probably go that route if the current motor lasts if not ill be going stock internals with fresh bearings and rings but looking for these parts specifically like every 4 valve build
96/98 cobra cams
Mach 1 throttle cable and cruise cable
96+ cobra fuel rails
Dowel pin upgrade
Navigator c heads
Head cooling mod
Rings, bearings, gaskets
It'll be fun hopefully
1998cobrasvt
Nice progress!! I like the game plan. - So how come your not using the fr500s? - I like the paint gun! Did you decide to repaint vs wrapping it?
Ineedav8
Ineedav8
South Florida
With my current a arms the wheels stuck out regardless last time i tried i had a 275 on it. And paint need to look around and get quotes on mixed gallons didnt want to just wrap over all the flaking clear coat
Ineedav8
Ineedav8
South Florida
Also hood popped up when I was heading to work today drove around fine noticed it got wobbly all of sudden and started slowing down so debating on aero catch hood pins or hidden ford racing pins in the grile
Ineedav8
Ineedav8
South Florida
Found seat leather from an rsx today!! Just need to install them there much better but still not perfect but for $13 im not complaining
Ineedav8
Ineedav8
South Florida
Need to assemble the teksid and see what im missing tomorrow drop off a cover to get a seam and a small tear stitched then maybe buy a shinoda wing at cars and coffee tomorrow we shall see depsertly want one but im undecided if i could rock one.. also debating on aero catch goodness or the hidden option
