found some bbs rk's
9838stang
Minneapolis,MN
I am about to pick these up possibly tomorrow. My only question is they are 17x8, 5x 114.3 with a 42mm back spacing. Will they fit my car? Wheels look pretty good. but im hoping they will fit and they dont look to flat on the front.
but anyone know if they will fit? or will they stick out of the fender?
I'm guessing since they're 8" wheels, they should fit. My 9" wheels with a 25mm offset fit, but rub when i turn the steering wheel all the way.
9838stang
9838stang
Minneapolis,MN
im just wondering with a 42 mm back spacing that they will be sticking out of the wheel wells like a chicano low rider....
jo4roush99
Griffin, Georgia, United States
Somethings not right here. A 42mm back space is about 1 5/8". This would make that wheel have about a 6" dish....but these wheels look almost flat at the front. I think he has his demensions backwards. I bet they will fit good on your car....might even need a small spacer to get them out of the fender wells.
ProKiller
PA
you're probably going to need a spacer to run them up front. they are going to be tucked in the fender more so then traditional mustang wheels.
det_riot
Dearborn
No no no no no! 42mm back spacing is for like s197 cars. You'd be super sunken battleship. See how there is zero lip on the wheels? Not what you want. Move along
Sent from my DROID RAZR using Tapatalk 2
9838stang
9838stang
Minneapolis,MN
Im gunna take a look at them, Ive looked at other images of simular wheels and from the ones he took, they look the same as other where they have a lip on them but as to how much idk i am gunna take a look.
det_riot
Dearborn
Don't bother, you need around 24mm backspacing for our cars. They won't fit right without the proper spaces.
a306juGRnot
sacramento
im pretty sure that he meant it has 42mm offset which is extremely high. itll fit but it will deff stick in and you prolly will not like the look at all. spacers will fix that issue though if you really like them.
thanks for backing me up on this haha are the faces of the wheels even concaved the same way?
Si, i dropped them off to get powder coated
They didnt the color so they order it and its gonna be 2 weeks to get them back
